It never ends... Broken Watts link..
JeremyH
3V Fuel Guru
Virginia Beach
First day driving the car to work, was fine on the way there. On the way home noticed some odd noise and some movement in the rear around turns... Got home and found this...
The center prop stud sheared off from the diff housing...
Some background, it's a techco watts link (improved saleen design) has around 15k street miles on it and maybe 30 track passes.
Can this be repaired?
Looking at a new watts, whiteline maybe or bmr whenever it comes out...
fdjizm
Drag Queen
Got to get in there with an easy out or something now, if you can drill a hole in the bolt that is in the diff.
also, sweet pants.
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
WTF....not that I know much about Watts links but how often do they fail?
Any idea on whether or not they have a lifetime warranty?
No overheating issues?
JeremyH
3V Fuel Guru
Virginia Beach
Looks like there is a set screw of some sort on the bottom, and I can probably easy out the bolt and look for a replacement one but more curious as to why it would happen and if its just gonna happen again or not. I was still in uniform just got off work lol
fdjizm
Drag Queen
It looks like a bolt failure, I'd just get a monster strong bolt to throw back in there.
JeremyH
3V Fuel Guru
Virginia Beach
It's actually a stud and a nut and washer go on the end. About to go out in a few and mess with it as soon as it cools down outside.
JeremyH
3V Fuel Guru
Virginia Beach
Well Techco doesn't quite exist anymore.... lol
I'm sure this kind of break was a long time in the making.
As you know 8.8 is the metric equivalent of a grade 5 sae. Replace it with a 12.9 and see what happens.
Seethrough
You should be able to drill the center of the stud in the cover and remove it. Replace it with a 10.9 or 12.9 grade stud or bolt. An 8.8 is equivalent to a grade 5 stud. Grade 10.9 will be equivalen to a grade 8 and 12.9 will be about 10% stronger than a grade 8 stud. Metric high grade hardware is hard to find so expect doing some research and paying a premium price for it.
Wes06
ffffffuuuuuuuuuuuu..........scary shit...
Thats why I like the units that run a double shear pivot point instead of single like above
JeremyH
3V Fuel Guru
Virginia Beach
Gonna try to get it out here in a few and see what Im looking at as far as length and thread pitch. Most kits don't have a double shear center pivot, not that it would help much in this case.
Wes06
well didnt it shear at the point between the prop and the diff cover?
Isnt that what double shear designs help prevent?
Like you said BMR link is looking promising, Kelly needs to tell them to hurry it up
Sharad
Site Sponsor
Fort Myers, Florida
Single shear is no bueno. That's why the cool kids are going double shear. If teccho is no longer around, maybe you can take it to a machine shop and add a plate on top of the center bolt, running out to two studs?
JeremyH
3V Fuel Guru
Virginia Beach
Well, jacked the rear up and got a clear shot on the stud drilled it out and got the easy out bit set good. But that stud might as well have been welded in place as I snapped the easy out and broke it, that fucker wouldn't budge, so it has to come off for sure. Probably just going to replace it with something else to get the car running again and see about fixing it later.
Shotokan1509
CT
Sometimes better to bring something like that to machine shop, Might be surprised they say no problem fast and cheap as they're used to it and have equipment rather than you messing with it for long time and potentially doing more damage to cover or yourself
