claudermilk
Ok, really mostly bad & ugly.
Two events to post on since I got behind and had a vacation between.
July 6th autocross, El Toro.
This was a fairly quick course and I ran into the rev limiter a couple of times. I guess I'm getting quicker now that I am seeing the problem with running 3.73 gears on an autocross? I suspect 3.55's are somewhere in my future. The course did have a few nasty little tricks in that you were sent into several slalom elements going the "wrong" way and the elements following did the same, making entry and exit more challenging.
As my second event after installing the suspension parts, I'm still playing with settings. I was also playing with getting my telemetry/camera setup dialed in and had issues with that (to the point I completely missed the best run of the day...sigh). I also had convinced a co-worker to try out autocross in his Golf R32; he had a blast and I think will be coming out again.
While my driving wasn't great--I'm definitely among the "hack" contingent around here--it wasn't awful. The second camera shows me I am not too bad on the cones I want to get close to. I seem to only be giving away 6" or so this day.
So, the videos:
July 20th autocross, El Toro.
Probably one of my worst showings in a while. I'm still playing with the Koni settings and I seemed to keep going in the wrong direction; I need to get out to a practice day & flog the car with many different settings to get a better feel for it. I know I overshot trying to balance the car & get a touch of overteer dialed back in--I got lots. Right now me tuning the suspension =
and
That said, after watching other high-HP RWD street cars I was not alone. Perhaps the windy conditions got the surface nice & dusty as I was not the only one struggling with the rear end. Lots of oversteer & spins during the afternoon. I guess as bad as I did, I at least wasn't "that guy"--a noob Miata driver was aiming at the workers on the slalom & I got to that station early enough to witness this & have to run away from the car. Scary.
The nice thing about running on old runways, is there is lots of space to play with. This was another pretty open, fast course and I ran into the rev limiter again. It also had the longest slalom section I've ever seen. I think I got the basic line and tricky parts figured out, I just never executed--even after 4 (!) reruns. With all that practice, I should have done better; in the end on the final run of my group a Camaro--the only other car in CAM in the results--just beat me.
He did take mercy on me & point out my tires sucked vs his; yes, if I was running 200 treadwear tires, I'd likely have a second or two on him.
As bad as my showing was, I have gotten better at my spacing off the apex cones. I need to get more consistent, as predictive timing was showing fast times on runs 2 & 4 before I blew those runs.
I am getting dealing with the cameras & telemetry dialed in. Just ran out of battery on one camera--I probably need a new one & some spares. I have to say the new RaceChrono Pro app is very nice. Once you have defined the start and finish lines, and have your BT devices defined it's set & forget. I have added the Garmin GLO GPS and ScanTool MX to the repertoire and the app uses them without a hitch. Now to learn how to use that data. For now, the app's new predictive timing is nice--big green box on screen & I'm doing better, big red box & I need to hustle and find some time. Oh, and yes, the roof cam settings were borked and since fixed. No more 4:3 720p.
The videos for your amusement
First time I've completely lost the car & spun it. Bleh. This was a fast run, too.
For my suspension settings, I am starting out about 1 turn from stiff in front and about 1.5 turns in rear. I'm thinking just even them out & start from my street setting of 1 turn from soft and bump 1 turn at a time and see how it does. I am starting to wonder if I need to grab some adjustable swaybars to tune the front-to-rear balance. I'll definitely play with settings on the Konis before throwing more parts at it, though.
So, the videos:
and
That said, after watching other high-HP RWD street cars I was not alone. Perhaps the windy conditions got the surface nice & dusty as I was not the only one struggling with the rear end. Lots of oversteer & spins during the afternoon. I guess as bad as I did, I at least wasn't "that guy"--a noob Miata driver was aiming at the workers on the slalom & I got to that station early enough to witness this & have to run away from the car. Scary.The nice thing about running on old runways, is there is lots of space to play with. This was another pretty open, fast course and I ran into the rev limiter again. It also had the longest slalom section I've ever seen. I think I got the basic line and tricky parts figured out, I just never executed--even after 4 (!) reruns. With all that practice, I should have done better; in the end on the final run of my group a Camaro--the only other car in CAM in the results--just beat me.
He did take mercy on me & point out my tires sucked vs his; yes, if I was running 200 treadwear tires, I'd likely have a second or two on him.As bad as my showing was, I have gotten better at my spacing off the apex cones. I need to get more consistent, as predictive timing was showing fast times on runs 2 & 4 before I blew those runs.
