A LOT of Cortex goodness inside
skulls
I just got all my Cortex stuff in...
Watts Link - Street
Torque Arm
Coil-Overs - Street (entry level with revalved konis)
Currently running the following suspension:
Tokico D-spec
Steeda extreme sport springs
J&M Extreme Joint UCA w/ Steeda 3rd member link
J&M Extreme Joint LCA's
BMR Relocation Brackets
BMR PHB
Steeda Heavy Duty caster/camber plates
(before I go any further...This thread is not meant as a debate on anything. As you can see the parts are already purchased and I am fully committed to running these parts. This thread was created because I have not seen much pic wise in the Cortex department, so I figured I would put it out there for people who might like to know. If you don't like their set up or whatever, awesome, it's a good thing I wasn't using your money ;-) )
After some time running this suspension, I wanted to try and get the rear end under control, it still really feels like there is a giant log underneath the car...While I think it will always have that feeling, after some extensive reading, I think the following set up will help get it as good as it will be and I think will be much better.
I did A LOT of researching and going back and fourth. I finally landed on Cortex and Griggs (please do not get into the chicken and the egg, here...I do NOT care who created what first), I spoke to both Filip and Bruce, both super nice and extremely helpful guys. I called both numbers and they both picked up the phone, that's pretty cool that you can call a company and talk to the owner with out issue. After conversations with both, I landed on Cortex for one main reason, IT'S FULLY BOLT IN, Griggs absolutely requires welding and, while you can weld with Cortex, it is not a requirement ..with Griggs it is. For me that meant, that I would have to do one of two things...either do the install myself and then flat bed to a shop and have them finish the welding or have a shop that can weld install and that just becomes way more than I want to spend. That also means that one day when I sell the car and I put it back to stock, it will be very hard to sell his stuff, because Ill either have to cut pieces out or hope that they can be purchased separately from Griggs. Mostly the cost of install and welding sent me to Filip and Cortex...Everyone thinks there stuff is crazy money, but in reality for the current offerings it really isn't. I mean the whiteline kit is roughly $100 less than Cortex and from reading and pictures, I think far superior (just my uneducated opinion, going off of forums and pics ;) ) and Whiteline has a bit of a peppered past. Plus CJ at Sinister Mustang hooked me up and I just couldn't say no.
That lead to the following...
Their entry level street coil overs with revalved Koni yellows. Part of me wishes they were the Tokcio D-specs that are double adjustable, but in reality I have no idea how to set them up and since I bought them, I have not messed with them. Also, I will be doing mostly street driving. I reality, I didnt even want to mess with coil overs, I like just installing springs, and being done with it...but I really HATED that design of the springs on top of the axle, in some stupid cups, that are held there just by the weight of the car. I understand that it has worked for many years and there are thousands of cars that run this set up, very effectively, but I think it is a stupid and lazy design. To me, the springs are just rattling around loosely while driving and I wanted to eliminate that. I did a LOT of searching and finding that almost no one moves the springs from the axle onto the shocks (again, because it is fine for 99.9% of people), Griggs and Cortex were really the only ones I could find that had set ups that made a TRUE coil-over set up, since I was going Cortex for the T/A and the Watts, I might as well keep with the name and rock their stuff instead of going another route. This just seems so much more secure and logical to have the springs on the shocks...the other advantage is that far out on the axle, they have more "leverage" and so you can achieve the same results with planting tires to the ground with a softer and more ride friendly spring rate. I love the stand of my car now (and so does everyone I talk to, lol), but they are rough and I guess I am getting old, because if I can get rid of that, it wouldn't hurt my feelings ;). As you can see the springs are eibach and the front caster camber plates are ground control...the entire set up is very well made and stout. The last time I have a set of coil overs was about 10 years ago, when you have to rings that you had to spin together and the tighten against each other and it was ALWAYS a pain in the ass to get them "unlocked after some time...these have what looks like a "set" screw that tighetens up the single ring, which seems like it will be a lot friendlier in the adjusting department. So now for the pics....
Fronts:
Rears:
Rear Brackets:
skulls
The Torque Arm (its a stout peices...it is heavy and should be able to take the punishment):
T/A Brackets:
This piece goes up into the drive shaft tunnel and connects to the body where the 2 piece D/S joint attaches and then attaches to the black piece which is connected to the floor on the underside of the car.
This connects the back of the T/A with the diff cover
skulls
AAAANNNDDDD the watts link:
The "rods" of the arms are aluminum and very light weight and look really nice...I dont know why I assumed they would be steel of some sort.
Since the car is a daily driver in Oregon, where it rains a pretty good amount, I got the rod end dust cover, Filip said to put a little grease in it and it should really keep out the gunk and crud from the wet from daily driving.
Watts Link Brackets and Brace:
Department Of Boost
Alpha Geek
I'm must be doing this stuff all wrong. I put things on my cars then drive the crap out of them. Not take pictures.:boobies:
skulls
They came in Monday and I work mon-fri, and while I don't have access to a lift...I gotta wait until the weeknds...so o figured id at least take some detailed pics, as some people might interested. Apparently you are not in the group that is interested.
2013DIBGT
I Hate Wheelhop
The Ungreat North East
Congrats on the kit and nice pictures. I predict you will be very pleased by the results :popcorneat:
A bit of advice if I may. If you plan on lowering the car abut 1 1/2" give or take use the next hole up from the bottom on the Watts Link roll center adjustment. IMO, the handling characteristics feel mo betta there as opposed to using the second set of holes down from the top.
skulls
I think I will as well...
Thanks for thr compliments on the pics.
Thank you very much for the advice...ill do that!!!
SD07GT
He likes taking pictures of his Eibach junk (lol)
Whiskey11
SCCA Autoscrosser #23 STU
I think that will largely depend on the car's setup with bars, springs, etc. My car, my Watts link is on the top hole which on the Fays2 is higher than the top hole on the Cortex unit and I'm running 550/275 for spring rates, stock 20mm rear bar and Strano front 35mm bar at full stiff. Car is as neutral as I'll ever make it but I'm also autocrossing and not roadcourse/canyon carving with it. Might be a tad loose at higher speed.
2013DIBGT
I Hate Wheelhop
No doubt..
IMO, the back end of the car felt a little to eager to try and match the front end turn in rate while entering turns at higher speeds with the RC in the higher positions on the Cortex Watts.
I'm currently running an Eibach FSB in the middle position (will go full stiff at some point) and no RSB.
Prior to removing the OEM rear bar on my car the above description was more extreme. Things got progressively better as I lowered the RC one position at a time. I then ultimately removed the rear bar altogether and everything fell into place.
I'm pretty happy with how it feels now but I've encounterd a small handful of driving situations (at 90% full retard speeds) where I think a VERY small rear bar would have helped to reduce skid marks in my drawers...:crazy:
As an experiment I just picked up what I am expecting to be an 18mm rear bar to try it out. Some have reported recieving 20mm bars from this source though so will see what I get when it arrives. The bar was cheap enough to be considered a throw away if it doesn't do what I am expecting it to do during those "small handful of driving situations". In truth, I could easily live without the rear bar on there though so no harm no foul either way for me.
Whiskey11
No doubt..
I can see how that would be. I've played with my Fays2 location multiple times and settled where I'm at in an attempt to remove the rear bar. I have the Strano 25mm rear bar that I took off and put the stock bar on because there was just too much bar. I'm at a point where the next major modification is going to be the rear diff and I think the Torsen T2R will pretty much force the removal of the rear bar which is what I want. More power down!
Just keep in mind what lowering the roll center does for weight transfer across tires and how that effects the contact patch.
