dysan
Dis-Member
Combo as far as my last best on the board?? Then very much so. My old 10.259 had a lower compression engine(10:1), no drag shocks or springs, more boost than this run and the cams were locked full advance.Thats an awesome pic. I would be buying that one and getting it framed. Did you change the combo any?
Dang!! Looks awesome man
Congrats!
From the looks of the launch, that car has a 1.35 in it, for sure.
Keep up the good work.
I seriously doubt I could get a 1.35 until I get weight out of the car and a higher stall converter. In the above picture the car with me in it weighs over 3900lbs!
I should be getting a trailer very soon and then the car will come off the road completely. That's when I can really start saving weight..I have a lightweight VFN pin on hood to put on, get rid of the back half of the exhaust, lose the Evap crap, get rid of the stereo, door subs and speakers, heater box/core, passenger seat, etc. I'd like to get a few 100lbs out.
In your picture, it appears that you are wasting energy. That is why I believe it has more in it. A good (low / quick) sixty foot time is not only about the tires achieving traction.
For example, when our car cuts 1.3X it is very drama free. The tires do not come off the ground. It just shoots straight and forward.
So - If I were you, I would shorten the driver side link on the ARB slightly...and I would try to shorten that IC up a little (drop the UCA down, or the LCA - depending on what parts you have)
Good luck!
If the car pulls and rolls to the right, you shorten the left.
In easier words....when looking at your picture, what will straighten the launch out? Lengthening the passenger side, or shortening the driver side. Right?
What LCA Relocation brackets are you using?
Do you have a link or pic of the one you are going with?
I remember the first time I adjusted mine, and got it backwards. The car lifted one side so much it cut the tire on the launch. FAIL. haha. Now it leaves like the 3rd and 4th pic below.
My car launches straight as an arrow and doesn't veer in either direction..I just have the torque twist on the launch. Correct me if I'm wrong but what the anti roll bar is there to accomplish is to keep the passenger tire and the driver's side tire essentially squatting the same on the launch so the car is level. That would mean to me that I need the passenger side to be pulled down away from the body since it gets thrown up towards the body from the torque and the driver's side gets pushed down into the ground by the torque so I would want to push that one up towards the car.
To me that all means that I must either shorten the passenger side link thus pulling down on that axle tube or lengthen the driver's side to push that one up towards the chassis.
