dysan
Dis-Member
Good luck! What are the 3vPA heads?
I think they are the same that I have....the Ford racing stage 2 heads.
OK, just got home, will post results and dyno soon, this is the final engine bay pic. This airaid piece is top quality.
Ok, engine tune and dyno is done.
Happy with the results.
We just made a new bracket for the steering reservoir and moved it rear and down ward, depending on how our tests of the electric rack goes, it will all be gone.
Car is running 91 as that is all we have, tune is conservative at around .84 lambda and mid 20s timing.
We ran it with the stock CAI/TB at first and then switched, we were almost pegging the MAF sensor so I thought that changing the combo would bring gains, we were running 350s with the stock thing so I was a little disappointed. But never thought about changes this big, making 30rwhp out of a CAI and a TB was just incredible.
Attached is the dyno with the last of the stock stuff and the bigger TB/CAI it made 386/348.
My guess is that a looser engine and the electric steering will put it in the 400s.
The heads used are the stage 2 from FRPP with stock valves. I spend more in the heads than in the short block.
I have a set of livernois stage 3 around but have not fixed them yet, plan was to use them on a bigger project I had in mind, now, I dont think I'll do that.
These heads and the stock rods I think would help to made more peak power, that and the 600 would make low 400s but I dont want the driveability of bigger than 500s cams now the cars is really nice to drive as is.
I know nothing about N/A cars, so why is the timing in the same range I run on my S/C car?
That's fantastic. Excellent results with the old technology 3v head, lol. Especially considering the safe spark advance. FWIW I see knock at anything over 26 degrees with my setup and 92 octane.
You have put together the ultimate budget build. Congratulations!
Awesome! I bet it definitely pulls good at that power level!
Pretty decent, what do you figure is causing the dip in torque from 4100-4500 RPM?
Interested to hear about electric steering rack. I have a 2010 and would love to make that
Upgrade!
Plan is doing before the end of the year as the coyote swapped car we did is coming back for more mods and set my car by its side and re pin the EPAS still in that car to my PCM and see how it behaves with speed.Interested to hear about electric steering rack. I have a 2010 and would love to make that
Upgrade!
Can't tell but by what I've seen before I would say 30/70 or even less, data shows it was struggling for air.How much of the 30 hp gain do you attribute to the TB and how much to the CAI?
I'm interested!Me too, I want to run a belt drive vacuum pump and need the space.
