After a lot of research online it seems that the 8079 isn't the best turbo. A lot of guys posting that the compressor is too large for the turbine. I have a lot of room up front so I am thinking of going with a CT43-7879. Go with the 3.5" v-band .81 ar. I will probably leave the hotside that is on the car now on there unit I get the turbo and see how much work it will be to change it to fit the new turbo. If it is going to be too much work I will change it all up. The 7879 has a larger turbine than compressor, which seems to be the way to go. Talking with others, the turbos they were advising me towards had an even bigger split between the compressor/turbine. I don't want to go with a 7675 and wish I had went bigger later on. Also, when I sent my 6765 to Lethe for him to try he took a pic of mine next to his comp 6765 and the turbine on mine definetly looked larger.
