weather man
Persistence Is A Bitch
Rpm427sc
That should be a full refund. Hope the buyer is protected.
Rpm427sc
my inner case actually looked worse and felt like 80 grit sand paper so yes I'm saying that looks like normal use after a long hardlife. I am saying that you could actually use the blower with probably no problems for a while based on pics, provided you bought a new bypass valve. you have to consider this is an aluminum case making tons of heat. the recommended interval for maintenance I believe whipple calls for every 25k miles. just so you know I'm speaking from experience and not theory : dont have pics but heres my receipt from laast year on mine. case and rotors came back smooth as silk with all new bearings and stuff. I personally think you jumped the gun on this one and should try to negotiate a rebuild with the seller rather than piss him off by badmouthing his reputation.
How did you pay? A lot can happen in 8 months man... I hope everything is documented...
That's a long time to wait to discover a problem like that.
Yeah, 8 months after the fact is to long to go back to the well. Expensive lesson.
If it was me I would see if there is someone in Europe that Whipple knows how can fix a supercharger. I mean there has to be someone on the continent that can fix it. 8 months is a long time to bring up an issue sadly to say.
you guys see it took 4 months to get it to Spain via the cargo shipping?
4 months does not make sense to me. I feel bad too but a lot happends on the ocean and in warehouses. I see perfect shipments arrived damaged.
agreed, but it puts the time frame a bit more in perspective.Yes, but even so another 4 months to inspect it is a bit long. As much as I feel bad for the buyer, I'm afraid he's on his own with this one.![]()
