Guys with Prochargers
waynemac
Lawrenceburg, IN
So I picked up a used D1SC stage 2 kit for my 09 GT and require a few odd parts to complete it. I've been reading post after post and as well have talked to Procharger and am still at a loss about a couple of things. First, the cooling fan, Procharger says the stock fan has to go, their slim fan is required. I have seen where some have kept their stock fan, wondering if someone with this kit can chime in on their experience. Also wondered if there is an alternative from the Procharger fan as theirs is stupid expensive. Maybe a GT500 fan? I understand they are slimmer? Second is the pulley size, this one has me completely baffled. I have a stock motor except for Brenspeed NA cams, no long tubes but catless. I'm looking to stay in the 450-470 range. I told Procharger this and they are telling me a 4.13 pulley. I haven't found a single post with someone using a setup like this and staying around that HP range. Most seem to be 4.25 to 4.5. I'd really appreciate someone's input that is running a similar setup. Thanks in advance.
swflastang05
Back for More
N. Ft. Myers, FL
If you're running the stage II system you do need their fan. I tried to modify my OEM fan and even looked into the GT500 fan but at the end of the day to run that system you need the proper fan. Not sure what to say on the pulley size, I had 3.40 on my P-1SC1 with 15 lbs and 4.25 with my F-1A with 13 lbs now. Not sure about the D-1.
lostsoul
2014 vett or 2015 stang..
Gay Area
I believe the 4.25 was the 9-10psi stock P1SC version but not sure about the D1SC.. Its been so long for me since I had one of the first prototypes and posted one of the first installs with tons of info which didnt get much response because I was light years ahead of all, and didnt even get thought of to be put in "Car of the Month" section. I mean I even showed how to blow the coolent out of the system right. all the steps that the crappy ATI cheap ass printer copies didnt show. Me.. aaaaaaaaaalllll me... not once thought of....
ohhh back to what I was saying..
Others right.. need high speed fan for stage 2.. I looked around and could not find the 4.25 from 10 years ago(fuck thats long) but I did find a 3.85 which should be a 12lb from my understanding. Now.. 12 is a bit much for stock but have heard people run it for years without pop. Also there are people that sware its best to get a 12 but de-toon the timing so it will kick in quicker and still be safe. But first find out if the psi is the same for the D1sc.
I have a weak side for fellow mustang people that think the color yellow is the greatest out there.
If lets ummmm... say.. someone states, "lostsoul your the greatest asset to all s197's and yellow is the greatest color PERIOD".. Then PM's me with their address
Then I would be obligated to ship my 3.85 pulley free of charge. :whistling:
bullitt boy
NJ
lostsoul
Gay Area
HAHAH!! Its cool.. just pm me your address..
I'm suppose to go to a relatives place today and I might find the magical 4.25.. its been so long and I moved so many times. I'm not sure.
bullitt boy
NJ
Dude I waited two hours , and you still didn't say the magic words.
lol.
bullitt boy
NJ
Hope he sends it to you, I actually already have a 4.25 waiting to go on when the ID1000 injectors go in and the o/r H pipe gos on
702GT
S197 Fanatic
Las Vegas
You can run the stock or GT500 fan if you're willing to do a bunch of fab work. The pipe routing of the Stage 2 kits vs HO kits is different, personally I don't see the advantage of the Stage 2 kit, most of the time I wish I had just bought my own pipe and fab it up myself. If you want to spare yourself the headache of dicking with fab work on the fan shrouds, just get the prochargers fan and be done with it.
I humbly suggest getting the ATI Super Damper and matching procharger crank drive pulley. I didn't like the way the procharger crank pulley was fit to the stock crank pulley. The ATI setup is stupid clean for fit/finish with an ARP crank bolt to top it off, and I feel much better about spinning my motor on a performance damper than the OE, it's definitely a better long term investment, but to each his own.
How many psi you see will strictly be determined by what is after the throttle body for restriction and how high you are going to spin the motor/blower. I run the 4.00" Pulley and I see 7psi by ~4500rpm, after that I couldn't tell ya since I'm wastegated for 7psi. I have hit 9psi around 5k/rpm once while I was dicking around with my MBC. The guy that ran my blower before me had a 4.25" pulley on it and claimed to make 10psi and 500whp, but failed to specify at what rpm. You can call Procharger and they will help you size your pulley too (if they say 4.13, just get a 4.00 and shift early, lol). As far as my boost readings, they are based on stock cams/intake/T-body and LT headers. I also have a 4.25 I could sell ya if someone else doesn't hook ya up. Not free though, lol.
To touch again on the fan, it has nothing to do with the depth of the fan/motor itself. It's the shroud. On the PS/DS leading edges of the radiator, the shroud is too beefy. The stage 2 pipe routing runs the pipe right up to the radiator pretty much and sends it down between the radiator and support brace. I suppose this helps keep the pipe tighter to the undercarriage so a lower car doesn't bottom the piping out (haven't heard much complaint from HO owners about it) but makes it a precision PITA fit up.
If you get the Procharger fan, you'll have to do something about your coolant reservoir and Power Steering reservoir. I bought JPC's coolant reservoir that relocates it to the PS strut tower, and bought line/fittings to extend it accordingly. It's roughed in right now, I plan to adjust some of the lines later. But it's an easy move and looks clean. The PS I kept on the procharger fan and zip tied the shit out of the PS lines. The AC lines are the fun ones to fuck with, the procharger drive belt path and crank pulley play all kinds of hell there. Have fun with that lol. I plan on having stainless braided AC lines made to clean it up, AC hardlines suck balls.
lostsoul
Gay Area
I sent it.. but damn.. I cant find the 4.25.. its been 10 years.. sheeeeeet
bullitt boy
NJ
My P1sc making 549 with the 4.38 pulley. Gonna kick it up just a touch.
