Motor is gone
94tbird
4R70W FTMFW
Took the car to the track for the first time this season and she let go on the first pass.
It was all a blur to me really and im still in shock about the whole thing but somewhere between shifting to 4th and the return road I lost all oil pressure. At first i thought oh well it could be the gauge acting up again, Ive had a few issues with the Nexus oil pressure gauge. Then i see the oil light on the instrument cluster and thing oh fuck. Yet the car is still running, moving and idling all on its own. Now im confused
I shut the car off and rolled into the pits and pop the hood. Everything seems to be in order, check under the car for oil and everything is bone dry, not a drop anywhere. No holes in the block, nothing.
Check the oil and as usual the dipstick reads nothing due to the moroso deep pan. Go to the store by the track and getsome oil and it took 2 quarts or so which means there were 5 or so in there to begin with so it wasn't a lack of oil. Start the car after adding oil just to see if the noise was gone....Nope clackity clackity clackity and it seemed to follow the rpms. At this point im packing up and calling my buddy to come with his flatbed to take me home
Spun bearing? Oil pump failure? at this point who knows. Im only going on 4 hours of sleep right now so im not in a very good mental state to be making decisions but I do not know what to do at this point. Soem of the ideas I've had were to part out the car and return it to as stock as possible and sell it, To pop a stock motor in and go back to 10psi, pop a stock motor in and leave it N/A, and sell/trade most of the performance parts, or to fix the motor.
I do not have the time or the money to be tearing it apart right now nor the resources to do so as I have never done this myself. I am pretty sure I will be done for the year at Min.
94tbird
4R70W FTMFW
Also got a set of MT 3055 and a set of MT 3057 tires brand new. All i want is what summit sells em for. I will give you free shipping so you'll save 30 bucks or so otherwize ill just send back to summit
Pumpkinfish
Johnny Quarter Mile
Schwenksville, PA
Sorry to hear about your problems. You seem to have had gremlins from the get go with this car.
Isn't that the cam phaser failure sound? Car sounds like a diesel when they go. Someone on this board posted a video if I remember right. I feel for you Ron. I went to the track yesterday and my tensioner is shot and one of the pullies is making a high pitch squeal! This hobby never ends, does it?
mikeysgt
Bakersfield, CA
Sorry to hear man. Hopefully it isn't that big of a problem after all. I might be interested in some of your suspension mods if you are planning to go that route...
akula52
South Carolina
that sucks
Dam Ron, that really sucks. Look on the bright side if there is one, you don't have any holes in the block. It may be something that is repairable at a reasonable cost. Just take a break, let her sit for a while and then decide! Good Luck Bro!
Pumkinfish, your symptoms sound like mine before I ripped the lower idler off my timing cover with a part of the timing cover attached!
Rygen
I can break any motor!
Wow, I know how you feel, loosing a built block is killer. Take a break, and clear you head and then have a look. Hope it works out for you.
94tbird
4R70W FTMFW
could it also be a phaser? how would you know a phaser was bad? just replace and hope?
I wantto take a vid of the sound but afraid ill do more damage
W1ldcat
St. Joseph Mi.
The phasers aren't that much and the vid did sound like the one Livernois posted. Just hope it's something simple.
MexGT
Mexico
IF it was oil problem, a phaser would most likely be the problem IMO, those things work with oil preassure, and btw, do you have limiters or lockouts? or none?
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Man, that sucks Ron. From what you described, it sounds eerily like what Ken3030 had happen back in Dec. Turned out to be a failed oil pump for him.
DKO
Shut up and die!
The Dirty South, South Carolina
Very sorry to hear, Ron. You just can't seem to break the streak of bad luck that follows you with this car. To me it also sounds like a failed pump.
Losing a built motor has got to feel like you've just been repeatedly kicked in the nuts. Sorry, again.
maxpayne
BIG UNIT
NJ
+1......
Sorry to hear that bro!Was it maybe because it wasn't driven for a while and oil wen bad.......
KIMMER
Admin
Hey Ron,
Let your blood pressure go back to normal and don't do anything right now. I don't know how many times I have done things while I was pissed just to regret it later. Stuff always works out. If you just had the engine done, I would think the builder would want to pull it apart and see what the hell failed and hopefully the part manufacturer will stand behind making it right. Was this a stock oil pump, or aftermarket? Seems like the stock oil pump is the best to use. I know me personally, if I built someone a motor and this happened right away, i'd tear it down and check it out for nothing. If this thing is built, there is no way it should have popped already and you don't have a hole in the block, so that's a plus. I won't look for someone else yet, because your ass is gonna snap out of it and figure out what's wrong with your car and run it at the shootout!:thumb:
KIM_05_GT
I think larry h built his motor and that guy is long gone. Sorry hear about the motor ron. Hope it's a easy fix.
Hey Ron,
94tbird
4R70W FTMFW
Don I hope thats all it is
that it does im just sick to my stomach right now
Hey Ron,
Motor had 7k miles on it and Larry turned out to be a VSOP so that's out of the question
It was a stock 3v Oil pump. I hear ya kimmer its just a very bad feeling right now
Kevin @ PMP offered to come up to NY and help me pull the motor and fix it using his Vacation time. I cant express enough gratitude for the offer and guilt that i would feel if i accept. Probably wont be till june so ill do as much teardown as I can to see what went wrong
