Motor is gone
05stroker
Never enough power guy!
Bullard Tx.
thanks guys. I was supposed to goto a track rental on monday, obviously not happening now. I was just going to go to work but i guess i could start the teardown then and see what happens
Now your on the right track . Get after it.
PNR Welding
Hammonton, NJ
OH shit, Im seriously sorry to hear this. Plus, im still using the stock oil pump. Im now even worried about mine. What kind of Crank pulley were you using? I see how this can be causing failures.
PNR Welding
Hammonton, NJ
I wonder if it could be how close the crank is balanced to zero. It doesnt seem that anyone is having issues with stock motor/stock oil pump.
Possible?
EagleStroker
N/A Junkie
Memphis, TN
Possible?
Anything is possible, but I would think the reason a stock motor isn't having issues is it can't push the power a forged block can. What were you putting to the ground?
one eyed willy
Pizzle fo shizzle
Lakeland FL
sorry to hear man....i just went thru this last month. from all the videos i have heard,they all pretty much sound the same. i had a bent rod contacting the crank on each revolution. ill post the video for you to hear what that sounded like. from what i have heard the #8 rod is usually the first to go ,i guess it gets less oil pressure than all the others.
http://www.youtube.com/watch?v=wefK316sYSA
sounds alot like th cam phaser noise but i was not that lucky. the sound was loudest from the hole under the transmission where the clutch dust is vented.
KIM_05_GT
IMO the oil pump problems come from the crank not being balanced correctly, or should I say close enough to zero.
Livernois using IW pulleys and they have no problem with stock pumps. And Livernois balances there assembles down to tenths of a gram.
Redfire
Ron,
I would take the front cover off and inspect the oil pump. The front cover is simple to remove and fairly quick with a super charger. When I lost my pump last year it was similar to what your describing. If it is the pump and you shut it off quick enough pull a couple of bearing caps to see if they survived. If they look good go with a stock pump with billet gears. Also cut your oil filter open to inspect for metal shavings as a precaution if the bearings look good.
SC boss
watch this!
Desloge Missouri
Sorry to hear Ron, you have my sympathy and my worries as I am running a Larry H. Stroker motor. Dont part with it, follow the members wise words have a beer or thirty and see what is wrong. Stand up applause for Kevin @ PMP for offering his help, he has spent hours of his time on the phone offering me information just because he is that generous. Best of luck to you man.
Shawn
one eyed willy
Pizzle fo shizzle
Lakeland FL
Ron,
where can we get just the billet gear?
ZmanM3
The Evil One
Jackson, NJ
Thats just amazing that it could still run like that. You have way more guts then I do revving it while it was making that sound.
Zman, I don't see how it could be related, I will die if it is!
I won't die but I'm worried about it.
Shawn
+1 on all counts!
Racingtheburg
I don't mean to sound stupid posting this BUT.... 5qts in a deep sump sounds like an issue? Lack of oil?
thump_rrr
Montreal Qc,
Hey Ron,
Sorry I missed your call bud.
The first thing I would do is pull the pan off.
At this point you know that the front cover will need to be removed to replace the pump but it's the rest of the damage you want to inspect.
If there is no metal in the pan and the bearings are ok then I would say that the clacking is from the chain tensioners losing pressure.
You would need to get Kevins pre-lube pump before you start it back up with a new oil pump.
I've got to run but I'll talk to you soon.
i'm sure there were 7qts to start, Ron added some to make sure b4 they restarted it
