ford and their pos hoods
mustangflanagan
south jersey
After all these years you would think ford could make a damn hood that doesnt flutter when cruising at 75 especially for the price of these cars now. Cheap asses.
WARstang
What exactly makes them cheap asses? That aluminum hood is of higher quality and more expensive to make than a plastic version, would be happy with solid steel? Maybe titanium? . I've never seen my hoods flutter.
ford20
White Plains,NY
Have you tried adjusting the bump stops or whatever they are under the hood? Both my 09 and 12 haven't had a hood flutter.
ford20
White Plains,NY
When I put my Steeda hood on I thought the damn thing was going to fly off so I adjusted both of them a little bit and went for a couple of test drives tweaking them each time and now it only has a small flutter so maybe that would help you if you did that.
BleedinBlue
Eureka, Mo
None of my three Mustangs I have owned have had such a problem. The corrosion, however...
Mr. Q
North of Seattle, WA
I had bad flutter in my hood around 70mph when I first got my 12. I noticed that the hood didn't really line up with the fenders and when I played with the nubs to get the hood looking right, the flutter went away. Good luck.
Ken04
gm troll basher
Santa Rosa Ca.
all 3 of my S197's have had, and do have the dreaded flutter. Hood pins don't cure the flutter but makes me confident at 140+ that the hood will stay on. I've heard the 2010 undertray in front helps too.
Renesis07
Plainfield IL
Haven't noticed this in my 2012. My 06 fluttered the one time I brought it up to high speeds and scared the heck out of me (at the time I didn't know it was a common 'issue'). Aside from that one time I never really noticed it in my 06 much either.
