Novi 2200sl Install!!
2007grabberGT
No vids yet! I want to button a few things up on it before I strap the go pro to it and thrash it! This weekend will be a Roush boost gauge,then maybe I'll shop for a Raptor shift light, then. . . . .
Scott
King City, Ontario, Canada
Nice moroso valve covers.
I am using stock throttle body with frpp intake manifold.
Took a good amount of modification to get the Paxton to fit 07 style for me.
Paul thanks on the valve covers, clearly I have more money than brains!
Did you modify the thermostat housing or reroute the hose after removing the Paxton spacer?
PNR Welding
Hammonton, NJ
Yes I removed the Paxton spacer and pretty much did the same as yours except the aluminum pipe I welded on is a little longer.
cm581978
NJ
how did you get the vent ring back on? i broke mine last wknd trying to put it back on the roush pod
2007grabberGT
The chrome trim ring I snapped onto to the vent pod out of the car, then reinstalled as a unit.
It was really a little loose and (per Roush instructions) I ran a circle of electrical tape around the vent pod , then snapped the chrome trim ring on. THEN I took a small razor and trimmed off all of the exposed tape off of the pod so it would fit back into the dash nicely.
