RedfireV8
How did you trim the cooling fin? I plan on installing some on my 05 GT, and don't really know how or what to use to trim them so they will fit. Will be using stock grill.
I used a Dremel which to be honest took a little bit so if you have something better use that. You'll be trimming the fins on the heat sink on the back of the driver side fog. They're aluminum fins so whatever can cut through that. You'll see what I mean when you get em.
