DVEST8R
- Joined
- Jul 8, 2012
- Posts
- 850
- Reaction score
- 1
A local track was having a drag radial prep test session so I decided to go. Approx 2300 ft da, I made 3 passes, a 5.8 and 2 5.9x. Below is a list of mods:
-stock block .020 over
- mod max h beams
- diamond shelf pistons 11.5 :1
-stock crank
-used cams
-on3 kit with there 78mm turbo
-fb 4r70w
-circle d stall
-3.73 gear
-full suspension- mixed brands
-275 drag radial
- mod max h beams
-stock crank
-used cams
-fb 4r70w
-circle d stall
-3.73 gear
-275 drag radial
Are you still on that stock longblock as in your sig?
