TR3650-XL Transmission 2005-2010 3v Mustang Complete kit. $4000
Postman
IL
This trans "KIT" is made by Astro Performance.
TR-3650 XL 800 Ft Lbs of Torgue Capable
2.90 1st gear Ratio with .57 Over drive
26 Spline Input Shaft
31 Spline Output shaft
Transmission Features the following Components:
9310 Alloy Synchronized 2.90 Close Ratio 1st -4th kit
Upgrade 1st/2nd shift fork
Billet 3rd/4th Aluminum Shift Fork
Brass Fork Pads
Dual Hardened Roll Pins
XL Tail shaft housing to Adapt Stock Electronic speedometer & Allows for 01-04 shifter
XL Tail shaft allows for slip yoke design Driveshaft
Premium Bearing, Synchronizer Ring, Seals and small parts kit
This trans shifts like butter. Because the shifter mounts to the tail section like a T56 Magnum XL there is no binding or missing gears and with the .57 over drive 4:10 and 4:30 drive like 3:31 in overdrive. I'm only selling this because my car is a turbo and I'm switching over to an auto. The trans is in my car now if someone wants to see it in action before you buy.
This "Kit" comes with everything:
Trans
Shifter
Alum. Driveshaft
Cross member conv.
Mcleod RXT Twin disc kit
Flywheel
Hyd. Throw out bearing
Pinion Flange
You will need to purchase nothing. $4000 for everything. Located in Woodstock IL 60098. I am willing to ship. Buyer pays shipping.
Postman
IL
2.90 1st gear
1.91 2nd
1.37 3rd
1. 4th
.57 Over drive
Racer47
Doesn't have much to say
SE Wis
These are G Force gear sets, 2nd is actually 1.91 not 1.19. These are the best spaced gear sets available including all the magnum stuff. These ratios work out very well for a 4.10 rear gear. Good 1st gear, not too deep, not too tall, 2,3,4 all nicely spaced and a tall 5th overdrive ratio to cruise on.
Its just too much cash for me to spend, plus I already have a clutch and alum driveshaft, shifter, etc.
Postman
IL
Thanks for the correction. Dam typo...
I love the trans I just think a auto with my turbo set up will go allot faster. On the street this thing is a blast.
I don't think your driveshaft will work . I had to get this one custom made due to the lenth of the tail shaft.
Racer47
SE Wis
For sure my driveshaft wont work. I didnt say it clearly but I would need to sell my ds, clutch, shifter, etc to recover some money after buying your setup and the difference is just to much for me to justify right now.
TRC51
With no idea....
How well with this trans work with 3:73's?
TRC51
Dumb question, but what does the shifter look like in the car... and what are the threads on it the shifter? Pics?
