20X10.5
KonaBlueBryar
im also guessing you guys are running really low camber right? my brother had about 1.9* camber on 19X9.5 drifts +35 offset and his tires rubbed on his coilovers. he only used a 275/40
DRock
DRock - are you getting new rims with a 42mm offset for the rear and a 33mm offset for the front? If yes, what wheels are they?
Yea. Im going to be running a +45 rear with a 3mm spacer and a +35 front with a 3mm spacer.
Low? mine is at -1.8* camber in the front. When you camber the wheel in the more offset you can use to push the wheel back out. And a 275/40 probably bulged a bit on a 9.5 so that could also have caused a problem.
Test fitted them today. 0 issues
KonaBlueBryar
reviving an old thread! hopefully you guys still check this regularly so ya can see this!!
Its getting closer and closer to wheel time for me! ive decided the "look" im going for would be a 295/30/20 toyo proxes... is that going to cause any cleance issues in the front? when i order my BCs im thinking about doing custom spring rates... maybe a 7k in front and 5k in rear. the "stock" rates are 5k in front and 3k in rear. i can stiffen things up a bit more to help keep my travel down. Main question is if the 295/30s will cause any problems. I saw that Champale was running the same size in rear, wondering if i can squeese them up front also
Champale
I haven't done a test fit but I would bet my 295/30/20 on 20x10.5 ET 45 would fit just fine. There is plenty of room around my front 285/30/20 PSS on that size wheel. Heck, 305/30 might even fit.
KonaBlueBryar
awesome! i appreciate your words of wisdom!!! cant wait to get this setup rollin man haha
