I am slowly and hopefully meticulously assembling my long block. A JDM stoker forged shortblock with ported big valve heads and Comp 127550 cams. I have the heads installed and torqued with factory head bolts. I also have placed the cams in the heads with Lubriplate on the journals and tourqued the cam caps. I was getting ready to install the locked out phasers on the cams and found that while I can turn the passenger side cam by hand with the phaser, I can't with the drivers side cam. I have double checked that the caps are in the right spot and facing the correct direction (looking at the number & > on each cap). Is this normal or are the caps too tight? Is it possible that the cam is not straight? What should I look for?
edit:
For my own curiosity, I used an old cam bolt and torque wrench to check what it takes to spin the cams. The passenger side spins with under 5 ft/lbs, the drivers side took over 20 ft/lbs
edit:
