After a long break of not even looking at the engine project I unbagged it and started tinkering. First thing I tried was remove the caps and rock the cam on the pivoting journal/tower. Decided it needed to move outward. Set my aluminum bar on it and gave it a few good hard whacks with a 2 lb. dead blow hammer. Did not seem to make a difference. Tried a few more with no change and decided that I just did't have a big enough hammer.... So I figure I had nothing to lose so I got out my old stock cam, wiped it down and then put some metal polish on the #2 journal. Laid the cam in with polish on #2 and assembly lube on the other journals, put the cap on #2 with the bolts finger tight and some resistance to spinning the cam felt and started spinning the cam. When it was noticeably easier to spin, I tightened to cap a little more, spun some more until it got easy to spin. I then removed the cap, cleaned up excess polish applied more the put cap on, tightened the bolts until I felt resistance to spinning, repeat process until I felt the bolts were close to final torque value and the can spun relatively easy.
I then removed the old stock cam, cleaned off the polish out of the journal and any residue I could fine. Applied assembly lube to the new 127550 cam and laid it an and ran the bolts down to finger tight and started to torque in sequence to spec to check how much force was needed to spin the cam after my polish job and of course my heart sank when the outside bolt on the #2 journal just spun. It is stripped. The good news is that with all of the bolts (except the stripped one) the cam with spin with <5 lb/ft. So, I get to do my first heli-coil... Once I get that fixed I can then check the clearance on the polished journal and see if the clearance is too much now.
I did do the rocking test and now the cam does not do any rocking while sitting in the head with the caps off. Once I get the stripped hole fixed I will check the clearance in several places of that journal (top, bottom, left, right).
Anyone happen to know what size the cam cap bolts are?
