What's my noise? Video included
linkwilliams
Is the car running bad? Is it missing on a cylinder? I swear it sounds like its lower end noise
isthatguy
Daphne, AL
it sounds just like that video, but honestly I havnt driven it since. it did have a CEL random misfire. and every so often it would buck and miss, but, I just honestly accounted that to the 95k spark plugs.
It actually ran pretty good.
isthatguy
Daphne, AL
Yeah I saw that video. Haven't had much time to mess with it. :( car is sitting in the garage z I miss driving it
CJ-
from California
Nota. Car has 95k in sure they are stock. If you want to come help, you are more than welcome! I live off of 181!
Bigchris. Phaser looks fine, from what I can see. And I unplugged the VCT and the noise continued
So any update on the issue? I know it's been 3 years but I'm curious. I have nearly the same noise, but alittle quieter.
pics06gtstang
SWFL n ft myers
after 3 years i would say he either got rid of the car or like me
ended up putting in the lockouts . p.s. thats after i put in new phasers and then had
a different noise on start up ( chain slap this time ) lil gasket on the tension-er blew out ( New chain setup from FREEDOM ) .
Then the fucking cam phaser noise again ( then i did the lock outs and bypass the vct shit ) .
SHIT SOUNDED LIKE A SOCKET WAS LEFT IN MY MOTOR !
isthatguy
Daphne, AL
haha, I dont know exactly what it was. I ended up replacing the valvetrain and timing parts and new phasers. that fixed it.
replaced all that, then built the motor! and still have car sitting in the garage :word:
Scrat
South Jersey
lol even though this thread was brought from the grave it does look like you had a pretty good size crack on the phaser.
isthatguy
Daphne, AL
no cracks, you are seeing sharpie lines from when I installed cams.
however the phaser was broke, a weld inside broke and the spring came undone.
gray06gt
Pretty common with the 3v. I'm replacing mine with comp cam limiters new ford phasers and a ford racing cam
Wes06
how does the phaser fail on this?
Mine is making noise thats awefully similar to this. When I pull it off does the phaser just fall apart or what?
isthatguy
Daphne, AL
it didnt fall apart, but I could see the spring inside wasnt tight and a weld broke. it was obvious, I even had limiters in mine.
