Why do I see so many 17X7's?
Untchbl
As I start to decide on which wheels both for street use as well as trips to the track, I'm confused by all of the guys that go with a 17x7 up front?
Are you guys using that extra tire because you are daily driving your "skinnies?"
Am I missing something by going thinner on a 17" front runner?
I plan to have a set of 19" or 20" wheels for street use, with my big and skinny setup only seeing time at the track and the occasional trip around town. I couldn't really find any info on this.
Thanks,
weather man
Persistence Is A Bitch
MN
Clear brembo and still have some tread for street, for me anyway.
Rypper1
Prairieville, LA
Thanks,
Exactly for me. Don't want to DD on true skinnies.
Untchbl
If I'm not mistaken, isn't there a 17x4.5 that will clear the brembo's?
So mainly for safety reasons when daily driving them a street setup?
JEWC_Motorsports
S197 Junkie
Yes there are 17x4.5's that will clear brembos. Yes you will have to slow down sooner because you will have less tire in contact with the ground and you will have to take corners a little slower.
Grabber Blue 5.0
I ran Weld 17x4.5's up front for several years on my 2011 and could never get used to the lack of braking. I sold them for some 17x7's and was much happier.
fast Ed
Caledon, Ontario CANADA!
Skinnies on the front of a modern car for the street are a great way to make it feel like a 50 year old car on the street as far braking and steering are concerned.
cheers
Ed
KrisR
Wyoming, MN
I use the 17x7s because I put them on before driving to the track, and one of the tracks I frequent is 200+ miles away (one way) from my house. I feel much better about driving that far/fast on a more substantial tire (215/60-17 in my case) than some little tire that is barely rated for the weight of the car. I put the matching rear 15x8s on when I get there.
ford20
White Plains,NY
Why would you run skinnies on the street when it is so easy to swap tires?! It makes no sense to me!!
Untchbl
I personally won't be running skinnies on the street unless I just haven't swapped the street setup back on and we are going out and about in the car.
I was just confused with all of the guys I see running the wider front "skinny"; but it appears they are driving them quite a bit more on the street than I will be.
