13mm ratcheting box wrench, a must with a header install.
this, THIS. As well as a 11mm if u are using stage 8 bolts on the reinstall
The ones I had the most difficulty with was the bottom front passenger side one since it's right against the AC compressor, and the bottom rear driver's side one...had to get creative there as the header tube and everything else blocks it from most angles. The rest were pretty easy.
Oh man, you guys weren't joking. I have spent three hours on my back and I cannot even get the H-pipe off due to how rusted the bolts/nuts are on the manifolds. It might call for air tools and a torch, neither of which I have.
Also, that upper O2 on the passenger side. WTF?
I'm curious to know. Mine came with exactly 16 clips, 16 long tabs or tangs or whatever you want to call them, and 16 short tabs which I didn't even use.
The good news is that after some more PB Blaster and creative use of ratchet extensions, I did get all of the required nuts off for H-pipe removal. But.... I am finished and the headers are not installed.
You guys are better men than me. After banging with a mallet and using a massive pry bar for an hour, I could not get he H-pipe and the clamps apart from the cat back. It is going to require heat. And that was supposed to be the easy part, haha. Ohhhhh defeat.
My time is too valuable to waste anymore on it. On the plus side I now have a killer set of ramps that I built, my garage has never been cleaner or more organized.
This is not good news, I had my H pipe off in 15 minutes, that was the easy part and I didn't have any issue with the O2 sensors either. I did have to unbolt the A/C compressor, and I unbolted and moved the rack forward for the steering shaft. Wait until the headers are on and you put in the top inside starter bolt. At that point you will invent words.![]()
Ever finish up the install? I see your in bucks county, I am as well if ur not far let me know if u need a hand! I've taken the stock storties off twice
I didn't finish the install. I decided that it simply was not worth it to be laying on my back wasting any more time than I already did. I have priced out the install from several local shops, but I am debating on cutting my losses and putting the money towards a supercharger. I haven't made up my mind yet.
I do greatly appreciate your offer to lend a helping hand though!
Getting the Kook's installed this weekend.
As a side note, out of respect for my neighbors, I am going on a search for a quieter cat-back as the FRPP Stingers are already a bit aggressive.
