Restoring grille?
Tungsten_GT
Long Island, NY
Since I've bought my car I've been trying to make it look better and more showroom like every way possible, but the grille is faded in one spot for some reason and won't come back to black, should I just paint it with trim paint? Or get a whole new grille?
28ONE
The City
http://www.s197forum.com/forum/showthread.php?t=114344&page=3
Check out the pics on post #54
The product I used is CarPro Dlux
http://www.carpro-us.com/coatings-sealants-spray-wax/cquartz-dlux-plastic-rubber-coating-sky-kit/
Here's acode for a discount: 15off
TenSpeed
Boss 227..every damn time
Michigan
Why not just use Plasti-Dip? One can for a few bucks and you are done.
AR Stang
Arkansas
If it was my choice for this particular mustang I would order a new grille with the pony delete, and skip trying to restore this one.
allworknoplay
New to the streets
Midlothian, Virginia
I personally would either make your own or buy a new one. I currently am working on a custom grille.
TGR96
el blanco nino
Huntsville, AL
His car would look sick with a center-mounted fog light grille:
http://www.americanmuscle.com/eleanor-grille-0509gt.html
94439
TenSpeed
Michigan
It fades? The hood vents that I did last year have not faded one bit. They look just as matte black as the day I dipped them.
Tungsten_GT
Long Island, NY
Thought about plasti dip, I've got the whole sprayer system and a gallon of black dip.
I'll definitely look into carpro, heard lots of good things about them.
Custom grille is pretty cool too, I currently have a foglight delete I made with some mesh, gives the car a mean look to it.
themoose06
Woodstock, MD
Pics of the delete? I was about to do the same thing
Tungsten_GT
Long Island, NY
This'll sound really silly, but it's window screen mesh. I then cemented it to the inside part of the grille. Only issue was at high speeds it would come loose, hence the reason I wanted to make some kind of gasket piece or something to hold it in place more securely.
themoose06
Woodstock, MD
Let me know when you've figured out a permenant solution! If I come across another oem grille i'll make that setup. Looks great man. What if you drilled holes in the cylinder about 1.5-2inches spaced out and then zip tied the screen though those holes? Not sure if that makes sense to you but basically zip tieing the screen to the fog light cylinder
