The point is that you have to make some corrections to the geometry in order to deal with lowering the rear in the first place, and my question is about how much of an improvement you really see from lowering the rear compared with running spring rates, sway bar rates, etc. that are optimal without lowering it. It factors into the next question (see below).
No. It's to put the entire thing into context. In the absence of a budget, when the fastest lap times are what one is after, then it follows that one will spend money on the SLA suspension to replace the strut-based suspension because doing so gets you much better control over the camber curve and, simultaneously, allows you to set the roll center to something better suited to racing (that latter assumes that the design is done with racing in mind, but that's a pretty reasonable assumption).
To do anything less means that one is making budget-based compromises, which means that one is going to be concerned with the best bang for the buck.
So my question in the latter context is: how does lowering the CG by less than 10%, while simultaneously having no impact on the roll center and causing a reduction in downforce, which requires spending money to correct the geometry in the process, provide more bang for the buck than would spending that money on, say, better coilovers, or a Watts link, or any of a number of possible options?
It looks to me like lowering the rear suspension may well be the last thing on the list in terms of gains to be had versus the price. I want to learn why it's not.
Do understand: it is in my nature to question everything. I do that because it's the most effective way I know of to reveal and get past assumptions that have been made. Assumptions can be incorrect, and it is not until one knows why something is done a certain way that one can know whether or not one should do things in that same way in the circumstances one finds himself in.
That's good to know. I have the Boss 302 springs (standard up front, Laguna Seca in the rear) and the 26mm sway bar, and it really made the rear come alive as well as substantially improving the turn-in, enough so that I don't notice a response delay in the suspension anymore.
By the way, I don't know what you did to get Filip here, but good on you for doing so! I, for one, hope to learn a lot and I think this will be an even better place for it.
" ... apeshit stridency is self-limiting in its effect."
— Mike L.
First, I did not contact Filip for him to come here. He did that of his own accord. Now that this is an open forum, I believe someone else may have informed him or he came upon it on his own. But that is exactly why an open forum is good and a closed forum is bad. The closed forum has led to some stale opinions on here. And I hope to see them challenged and corrected by better men than me.
I'm on 302 springs on Koni Yellows with a 26mm rear bar. The rear bar is what I expect has really changed the handling behavior of the car. Why did I go with the Boss 302 suspension setup? Simple: because the Laguna Seca is widely regarded as handling extremely well by quite a few (not necessarily around here, though. Heh), and I expected that because a good handling balance was something Ford was after for it, they probably would have achieved something at least decent after all the testing and tweaking they did. Given my specific requirements for ride height and street use, it seemed like a reasonable starting point. So why the Laguna Seca rear but standard Boss 302 up front? I did that because I'm running a square setup, and figured the slightly increased rate up front would simultaneously do a slightly better job of keeping the suspension off the bump stops while yielding a Laguna Seca like balance with a square setup.KC, I have gone both directions. I have gone with 302 springs on Koni Yellows. Ok I guess. then I put the T/A Watts Link rear end on and that was a game changer at stock ride height. I immediately gained much more confidence in the handling of the vehicle.
I'd like to see that video!Now, I have the Coilovers too and I run them on the street as High as they will go which is about an inch lower than stock. I am also running 275/40 284/40's because of horrible road conditions. I clear parking blocks. I will not brag about the handling, soon there may be a youtube video on it and people can judge for themselves.
I'm pretty darned happy with the way the car handles right now (it feels responsive and controllable -- what more could anyone want?), but that's always subject to change. What I change next will depend entirely on what I feel needs improvement at the point I become dissatisfied with what I have.if I remember correctly you have the stock 302 springs. If your goal is to get your car to handle great without sweating suspension geometry issues than you would love a Cortex or Griggs rear end, lest you think I am pushin Cortex. You can get great handling without stiffening up the car. I have been trying to tell people that but because I am not Vaughn Gitten jr., as you know, several have refused to accept the possibility.
Well, my next track event is at Sonoma Raceway in June. That may well prove to be an opportunity to talk to him just to get a feel for the possibilities, if he's there at the time (it's during the weekend, so he might not be there).So if I have an answer and I don't just an opinion based on my subjective experience without any objective data whatsoever, it would be NO you don't have to lower your car dramatically to get excellent handling. But the better answer is ask Filip.
I am guilty of communicating the subjective improvements the Cortex Rear End provided. It is you who is quoting out of context what i said, because as you well know, I said a lot more than "supercharging the suspension" And I do stand by that incidentally, in that it has the comparable effect on the suspension as a supercharger has on acceleration.
Here is a perfect example of the bullshit you spout, practically every time you open your (metaphorical) mouth. Your allusion here is that I am in some way denying Filip's credibility. I am not, nor have I ever done so. So, to support that allusion, you bring Bruce Griggs into the mix, who is also a pretty gifted Mustang suspension engineer and designer, apparently for the purpose of supporting your argument that I have denied Filip's credibility, which I didn't. Let me make this really clear, so that even somebody as apparently brain-dead as you can understand it: My problem with you is NOT that you are advocating some random part that I don't use, but that you expect all of us "unwashed masses" to simply accept whatever SUBJECTIVE impression that you might have, probably from your innate need to have the rest of the world regard your buying decision as brilliant and inspired. I won't accept shit from you without hard data to back it up. I also won't accept shit from anybody else under the same circumstances. You repeatedly failed to back up your assertions, and instead started making all sorts of accusatory and inflammatory comments and statements. THAT is what I have a problem with, not the Torque Arm specifically. Any assertion that ANYBODY makes has to pass the "bullshit test." If Filip or Bruce Griggs came on this forum and said that the ultimate road-race suspension design is an I-Beam front axle, made from cast pot-metal, it wouldn't pass the bullshit test. It very well might be true, but I would need to see empirical, objective data to support their position, not just accept it because of who they are.If Filip explained to you why that is to your satisfaction or not, I don't know or really care. I am sure Bruce Griggs could come on here and give you a similar dissertation.
Nope. I never said your subjective experiences were wrong or false, I simply asked for the data to back it up. That's the point you just can't seem to get through your skull. You said "this is bitchin!!" I asked you to "define bitchin." You got your panties in a wad. End of story.You denied my subjective experience and you expected to me to back down and why would I back down from something i truly believed?
And you thought you had no messianic complex... If anything, I have done the exact opposite of what you accuse me: supression of knowledge. "Taking things on faith" does not promulgate knowledge. Asking "why" and saying "prove it," on the other hand, does. So much for your "bullshit orthodoxy." Oh, and just for the record, the phrase isn't "whaling and gnashing of teeth." "whaling" is the activity of hunting whales. You know, like in Moby Dick. The actual phrase is "weeping and gnashing of teeth." Luke 13:28; Matthew 13:42, 8:12, 22:13, 24:51 and 25:30. I guess Matthew liked that phrase. Finding those references took me all of about 30 seconds. I guess accuracy isn't worth your time, which is typical of your posts.When I didn't back down there was much whaling and nashing of teeth and even now it threatens to devolve out of control because I challenged some bullshit orthodoxy. Whether it was coilovers allegedly punching through shocktowers or the plain superiority of a torque arm, whatever my meager credentials, I have advanced the knowledge that you have tried to prevent.
Really? You now control access to Filip? I can't just pick up the phone? Perhaps I did, perhaps years ago, when the Spec Mustang series started up. Better chide him for allowing one of the heathen unwashed masses a personal interview without your coordination. [/sarcasm]And had I not challenged it, you would not have the opportunity to communicate directly with one of, if not the, leading Race Team Engineers in the highest level of Mustang Racing.
No, we didn't. We shot you down for acting like an idiot. We shot you down for being completely unable to support the assertions you were spouting. To reiterate: we didn't shoot you down because you used Cortex parts (or any other parts for that matter). I can't be more clear than that. This is another example of your messianic complex at work; YOU are the Mouthpiece of the Lord; and we are the Philistines refuting the Word of God? Get over yourself.I was his advocate early and you all shot me down for it.
Of course I address him with respect; when he speaks, he not only knows the difference between subjective and objective, but can bring data, physics, and engineering to the table in the discussion. I'm glad that you feel vindicated, but I'm still not sure why. It's pretty obvious that you still don't "get it."Now you speak in measured tones when he addresses you. I get immense satisfaction out of that. So I feel vindicated.
This isn't the first time that you have accused me of specifically saying that Cortex rear coilovers will or have punched through the rear shock towers on an S197. Could you please point me towards that specific statement, or at least a link to the thread, and page? I vaguely remember the thread, and there was some concern about force-loading in an unreinforced shock tower (with or without the cage tied in, if I remember correctly), but I don't remember the specifics.And please feel free to address with Filip how many coilovers of his have punched through shocktowers. Because there is much misinformation to correct.
Debate is good and this is the reason.
SoundGuyDave said:This isn't the first time that you have accused me of specifically saying that Cortex rear coilovers will or have punched through the rear shock towers on an S197. Could you please point me towards that specific statement, or at least a link to the thread, and page? I vaguely remember the thread, and there was some concern about force-loading in an unreinforced shock tower (with or without the cage tied in, if I remember correctly), but I don't remember the specifics.
i remember a post like that, and had me looking into the strength of the rear mounts because i wanted to go full coils. here's the post i remember:
http://www.s197forum.com/forum/showpost.php?p=1269462&postcount=11
there could be more, just not sure. here's the entire thread here:
http://www.s197forum.com/forum/showthread.php?t=69139&highlight=rear+coilover+weak
I won't have an answer for you until after I've digested it all. And sanity-checked that.Did Filip address this issue to your satisfaction?
Barbaro,
Yes, you did a good thing bringing Filip into this forum.
I have neither the knowledge nor the experience to know anything about suspension components outside of what it is and a basic understanding of it does so I figured I would bring someone who knows everything about the S197 chassis in and help with the discussion. That is all I can ever really add to these conversations.That was meI have neither the knowledge nor the experience to know anything about suspension components outside of what it is and a basic understanding of it does so I figured I would bring someone who knows everything about the S197 chassis in and help with the discussion. That is all I can ever really add to these conversations.
I'll second that!
I think it's interesting that the problems with the 3-link's SVIC come into play when the car is lowered to race height. But that raises the question: why lower the rear in that manner? We're talking about racing, in which appearance is irrelevant. So what if the rear makes the car look like a 4x4? If the geometry is good back there, who cares?
If you lower the rear by, say, 1.5 to 2 inches, what are you really gaining, assuming that your geometry and spring rates were optimal prior to the drop? Sure, you lower the CG slightly, but (from what I've seen) you also move the rear suspension's roll center by about the same amount, so the roll arm's length remains the same.
Dunno if they're truly stale or not. I suspect what we're really looking at is multiple ways to achieve the same thing. But without understanding why a given approach works, it's not really possible to ascertain whether or not that approach will work for a given set of circumstances.
I won't be lowering the front of the car any more than this because I have to clear my driveway, and it already barely does so even though I come in at an angle (coming in straight would destroy the splitter). The front simply cannot tolerate any more lowering and still meet my requirements.
That could happen relatively soon, or it might never happen. But knowing how and why changes will help will hopefully make it obvious what that next change should be, should it become desirable to make a change in the first place.
For now, I remain focused on the driver mod. There is a long way to go in that department. See below.
But it may be quite some time before I make any changes.
Let me put all this in perspective for you. The Boss 302 on street tires is capable of 1:40 lap times around Laguna Seca. We know this because both Jonathan Bomarito and Randy Pobst have managed to get that kind of time.
If the car is already that capable, then failure to achieve anything close to that lap time is unlikely to be on the car if the car is set up in a similar fashion to the car they drove (which is how mine is now) -- it's on the driver. This is why I try to modify the car only when I see some obvious characteristic out of it that I don't like, such as the ride over bumps (which prompted me to change the dampers -- the Konis are massively better in that department) and the time it took the car to take a set (which prompted me to change the springs and rear sway bar. I also wanted to explore a different handling balance that I knew was generally highly regarded, and it has not disappointed!).
As I get faster and better as a driver, faults in the car will presumably become more obvious. Right now, I can't really detect any that are truly bothersome. That is obviously subject to change without notice.![]()
I was just thinking about this and it popped into my head that the Torque Arm is one of the pieces that Cortex recommends you buy before the coil overs if you are piecing together their suspension. I would for some reason assume that they put the torque arm as the component to purchase before the coilovers as it would be more beneficial to buy those than the coil overs. As for the reason why, I'm not sure.
I'm hoping he'll become an active participant in the technical discussions here, because I think we can all learn a lot from that.I completely hear what you're saying and to some degree I felt the same way. I have wasted a lot of money on a lot of things. And it's not so much that I'm pushing cortex it's just that I don't go on here and disrespect other people's products, but believe me I could.
The cortex rear end assembly is the best suspension mod I ever made on any car. I know that doesn't count for much. And I wish, I could have communicated that a little better from the outset. I didn't mean to come off as an authority. I was just overly enthusiastic about what I legitimately thought was a really great thing. Fortunately, for me, it is a really great thing, but nobody's going to believe me. I get it.
As for how its going to affect your lap times, I just can't see how you would be slower, but again I will only speak for myself. I am sure Filip could ballpark you a legitimate estimate on potential lap time improvement. But again, I am far from an authority. I do not pretend to be. I am just a guy who is a bit obsessive about customization and ride feel.
KC, you Know how if you wake up one day and everybody's crazy and you're the only sane one, guess what? anyways I really regret all of it and let it stand as an example of how not to make a point.
Interesting. I have to wonder what that does to the balance. With the adjustable Watts Link, however, you can control the rear roll center of the vehicle, and maybe that's enough to get the car back into balance, at least with respect to neutral throttle.My understanding both from talking to Filip and also from reading about others running his suspension, is that with a torque arm, Watts Link in the back you do not want a stiff sway bar, because it takes away both the the added articulation that the WL T/A rear end gives you and grip. Again he is in a much better position to address that point than me.
Yeah, that's exactly the experience I've had as well (see, subjective impression is valuable!).My personal experience is that when you put the stiff sway bar on it really helps turn in and make the car really good slaloming or in quick transitions.
Oh. You no longer have that in the rear anymore? Given what you say below, I guess that makes sense.It also makes it hard to put the power down on corner exit which is why my car drifted so good when I had that big H&R 26 millimeter sway bar on it .
So his set up is big front bar, small rear bar, control rear end with spring rate and dampers. He sells an 18 millimeter bar for the rear end which seems like a strand of spaghetti compared to stock..
I think the philosophy is to Keep your nose down in corner entry and load up your outside rear tire on corner exit. Now I'm not sure I have that right but it's more or less what I have been reading.
That's quite interesting. Did you ever have your 26mm bar on the car with the other pieces (torque arm and watts link)? If so, what were your impressions of it before you went back to a smaller bar?I do know if you put a Cortex rear end on,
Filip will advise you to go to a smaller sway bar.
OK, thanks. I'm at 191 lb/in in the rear right now, which is so close to 200 as to make no major difference. But my front is at 148 lb/in, which is a lot less.I currently have a 24 millimeter sway bar in the back and I'm going to be going down to a 20 millimeter sway bar that I have hanging around. I just have to get around to putting it on. It's a little bigger than what he recommends, but I also run softer springs than most people who run an 18 inch bar. My rear springs are only 200 pounds and my front Springs are 400. My car is a street car that can handle a limited amount of track Duty not vice versa.
Right. The nice thing, though, is that Filip is an engineer. He solves problems. If you want the car to have certain handling characteristics, he'll be able to come up with something that gives you that, as long as what you're after is within the reasonable realm of possibility.But I do know that nothing is set in stone and everybody has different driving styles. So what works for Filip may not work for you.
