I think I've found what I'm looking for (thanks eighty6gt and norm).
http://www.vorshlag.com/product_info.php?cPath=141_142_179&products_id=642
See post #17.Who's still turning wrenches on old beater 2008 cars?.
and slower through the corners than a GT350 or even a decently developed 6th gen GT.Should be saving for the new GT500. Supercharged 5.2! Lots of power
As for the front strut mounts, the GT and GT-500 ones don't allow for any camber adjustment....and are one time use only, which really makes em semi useless.
The oem is 3/4" taller on that pix..not 1 3/4". It's 22.75" NOT 23.75" on the pix.
The Vorshlag bilsteins won't lower it any more than oem. The distance between the
very bottom of each strut....and the lower spring perch is identical. With identical springs..and same weight, the springs will compress the same amount ! Your ride height will not change.
Thanks Jim, it finally "clicked". Sheesh, I feel like an idiot. Lol!
And Traveler, you're close. According to Vorshlag...
"Note: 2005-2009 Mustangs can use their stock top mounts; 2010-2014 mustangs will need to order the GT500 top mounts in the options below if not ordering with Vorshlag camber plates."
Right out of the box . . . what you describe does not generally mean that the shock is bad, only that it lost its prime. I think the following quote came courtesy of Brake & Front End magazine, earlier this year. I'd noticed the effect a long time ago, without understanding why until seeing this.II just saw another Koni yellow.... where the piston had zero resistance in one direction, defective....brand new....right out of the box....pita. (could be pushed in, with hardly any effort..vs the mating koni).
You prime them again by compressing/extending the piston a few times by hand with the shock oriented vertically. Basically squeezing the gas back to where it belongs.Gabriel Ride Control LLC said:Priming Twin Tube Shocks and Struts Differs from Priming Monotube Units
Occasionally, light-vehicle twin tube shocks and struts are misdiagnosed as faulty when removed from the box for installation. On the initial stroke of the product you may notice a dead band or erratic damping at the top of the stroke of the twin tube shock or strut. This is a normal occurrence and the shock will function properly once it has been primed.
This characteristic occurs in all twin tube shocks and struts because they lie on their sides during shipping and storage. Over time, the oil and gas inside twin tube shocks or struts moves between chambers while the product lies on its side. When the oil and gas are mixed in the working chamber, the damping effect may be irregular. Priming the unit removes the gas from the working chamber and moves it back into the reservoir. This is a normal operation that occurs once these twin tube shocks and struts are installed in their proper upright position in the vehicle.
