All Brembo brakes the same ?
Gabe
Whippled Coyote
I used the aluminum brackets the dude is selling on svtp and eBay, used them on both cars, they spaced out the rear caliper about an inch allowing the use of the '13-'14 GT500-size rear rotors (about 13.8") instead of the puny factory rear rotors:
Gabe
Whippled Coyote
Gabe-
So you didn't have to pull the axles to install those brackets?
Nope.
Just pull rotors and calipers, install brackets, reinstall calipers and rotors.
I also installed new pads at the same time but that's optional unless they're worn.
Either way, because the new rotors will most likely be thicker than the old ones, you'll need the special tool to wind the caliper piston back in, so the pads will fit.
Gabe
Whippled Coyote
o2sys
I have 13 GT500 rear brakes. Pulled the axles to install the brackets and I reused my 07 GT rear calipers. The calipers were identical.
kallar68
That's good to know, and those are 14" rotors? Reusing the same calipers and pads?
TGR96
el blanco nino
Huntsville, AL
Did someone say rear BBK?
Here's mine from Steeda. Yes, you have to pull the rear axles, since this kit has a solid billet aluminum bracket to replace the stock piece, but it's not a big deal. Reuses the factory calipers.
o2sys
Yes reused same caliper and pads. Same brake lines and parking lines as well.
Casting and markings were identical. With my OCD I would have replaced it even it was slightly different.
These were early 2013 GT500 takeoffs that Renegan Racing was selling off their track cars.
kallar68
Awesome, I'll probably do the same in due time.
