Converted to blow thru
black N boosted
Boosted
Perkasie Pa
Had to ditch the draw through setup and converted to blow thru.... I have a question regarding the diy power pipe, I can seem to get to fit in there perfectly- any sugestions? U can see in the last pic how it's raised to high to where I can't shut the hood! Seems to be hitting
05stroker
Never enough power guy!
Bullard Tx.
Rotated the pipe in the coupler? I had to do the same on my CAI on my 6.7 Super duty.
MassMustang
Southeastern Mass
Yupp! That's what I did. Rotate the elbow coupler up a bit and rotate the 45-degree pipe downward a bit. I'm still waiting on my Race Port BOV from TurboSmart though.
Nice setup you have!
o2sys
What did you use to plug the two 1" ports that remain after removing the stock bpv?
MassMustang
Southeastern Mass
In my setup, one was plugged by a welder when he mounted my PMAS flange. The other is currently being used for a 25mm Kompact BOV (which I think is too small).
I just bought a 52mm Race Port BOV from TurboSmart. I still have fluttering but I think I need the softer spring in it.
Sally B Shelly
I was going to ask the same question as 02sys. I will be converting mine soon but was wasnt sure what to do with those holes.... Thanks!
black N boosted
Boosted
Perkasie Pa
I'm running the 2 psi spring in mine, I believe it's the green
o2sys
Did you guys get a drop in peak psi after the conversion? I was expecting some drop of 1-2 psi as it's less restricted but still getting the same as before (10psi)
MassMustang
Southeastern Mass
Personally I couldn't say as mine was built blow-thru from the beginning. Plus I have a lower compression ratio (9.6:1 roughly). With the 3.12" pulley I'm only building about 12psi of boost.
black N boosted
Boosted
Perkasie Pa
I converted and went with a 10% overdrive pulley at the same time and I'm seeing 15lbs at 6k rpm
