JLT oil seperators question
Phil
College Station
So Ive had these on for about 1 oil change, i opened them to check them and empty any contents, only the Pass side had any oil in it, small amount, the drivers side was dry as a bone, is this common? Do I even need the Drivers side?
J B
Goldmember
SC
Drivers side is usually for boosted applications
Sent from my SAMSUNG-SM-G920A using Tapatalk
Phil
College Station
06 T-RED S/C GT
Carnegie, PA
I provided 2 more links for you in my previous post that was edited.. Also type in different questions in the search box.. At any rate, on a Coyote 4v the PCV/vacuum is on the passenger side cam cover which is exactly where your catch can is supposed to be trapping oil from.. Therefore you do not need to run a second can on the driver's side, as your driver's side is your fresh air/ventilation intake port..
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
There driver side one will only have oil from either forced induction or long periods of high-RPM full-throttle, like you see on a road course.
06 T-RED S/C GT
Carnegie, PA
Especially when it concerns centrifugal type displacement blowers that don't include integrated boost bypass valves like those from a positive displacement type offer.. For additional protection, there are also billet oil cap breathers that include integrated one way check valves which also vent the crankcase during long periods of high-RPM throttle just as you mentioned..
