This issue has been bugging me for a week and I'm stumped.
I have checked the voltage and ampage on the battery and it is good and I even replaced it. I have replaced the alternator through warranty for a new one even when the last one tested good and I have cleaned the battery terminals real good. I've checked all fuses and relays and they are good. Checked the starter wires and they are good and tight. SJB is dry as the desert and so is the carpet around it. All main chassis grounds were on tight.
What is happening is the computer seems to reset itself when any kind of electrical stuff is being used. Even when I open the doors and the window automatically comes down an inch or so. It doesn't start period now and no power appears to come on EXCEPT the slowly flashing anti theft light and the airbag light if I have the key in. Before, no power came on period. Everytime I try to crank the car with the key, it either does nothing at all or I hear that sound the instrument cluster makes when you reset the ECU.
Yesterday, it worked just fine. I drove it for a couple miles with no gremlins and started it up and off a dozen times. Then I park in the garage, close the doors and hit the lock on my key fod and bam, all power goes out. I try disconnecting my battery and instead of my alarm going off when I connect the negative terminal, it clicks nonstop as if it's trying to off but can't. Like as if it doesn't have enough power.
This all happened last friday when I was parked, driving home from work and out of nowhere the car's computer started resetting itself while the car was driving but the actual motor wasn't turning off. I made it just far enough home in my driveway then the car wouldn't turn back on again until tomorrow when I disconnected the battery and let it sit for a couple hours. The day after, the motor was turning off while the same symptoms were showing though. All dummy lights like ABS, TCS go on, gauges reset, radio resets, lights turn off and on and you get that braking feeling.
All in all, sometimes it works 100%, sometimes half the car works until I hit some electric stuff with or without the motor on and sometimes I get nothing.
Here is a video of what it is doing right now, and you can clearly hear the noises and computer clicking. One of the clicks is me constantly turning on the lights which causes the computer to reset ( or the use of any electrics it appears ).
How do I go on about finding the problem? I'd hate to take it to a mechanic and get charged an arm and a leg.
https://www.youtube.com/watch?v=k3-gEowkc2Q
