Ever miss your fog lights?
travelers
Eastern Pa
I don't miss them at all. I went with the CS lower grill with the little fog lights that almost do nothing but look some what good and the CS upper grill with not lights at all.
I don't miss them at all. I went with the CS lower grill with the little fog lights that almost do nothing but look some what good and the CS upper grill with no lights at all.
That CS upper grille looks good. If I were to use the CS lower grille, I think I would opt to forget about the lower fog lamps... and get the version that can have the front brake cooling ducts.
I used the CDC lower grille...then a few years later, installed the CDC optional front brake cooling duct kit..which came with a pair of 2.5" silicone high temp hoses, new dust shields etc. They now advertise it using 3" hoses. No more brake stink using HPS pads on oem 12.4" sized power slot rotors. The dust shields were for 14" rotors..and work just fine on the smaller 12.4" oem style rotors. It was a good compromise, since my wheels won't clear the 14" rotors. Front brakes don't get cooked with occasional heavy abuse on the street or hwy. This is on a 2010.... which I believe works on a 2010-2012.
