Does new Paxton setup require new belt?
06StangGT
Syracuse, NY
It's been a while, but I've been busy in the garage. I ran the 2200SL package on the stock bottom end for 2 seasons (roughly 4k miles) before I wanted more. Bought a built block and I'm piecing it all back together. I'm wondering if I can use the belt size I've been using from the Brenspeed kit or a way to measure which size for future reference. I did a search but didn't find this setup.
3.4 Blower Pulley
A/C Delete Pulley
15% IW O/D Pulley
Thanks for the help!
06StangGT
Syracuse, NY
If you're not changing any pullies your current belt size should be fine.
Thanks for the reply. I went from stock balancer to a inn west 15% OD, and also eliminated the ac. No sure if the belt I have now will fit. I plan to get it all back together this weekend so I’ll be giving it a test fit soo.n enough
01yellerCobra
San Diego, CA
Yeah. You'll probably need a new belt then. I would do the strong method unless you have a spare belt you can cut up.
