Wanted to post an update for everyone. I've been working with my tuner and am now on a new version for about a week. So far, I have no codes and it runs great in all conditions. I'll keep everyone posted as time goes on, but hopefully it was just a slight adjustment in the tune.
This is a funny post I'm making due to me checking my car w\ my Foxwell N301 scan tool (was bored) sometime after this thread's conclusion & I noticed that the IM readiness light was yellow instead of green (indicates that there was a monitor that hasn't set or a pending DTC code has set, red light shows a permanent DTC code set) so I went in to check & saw that the spark monitor had a pending DTC code set & guess what it was.....P0300 random misfire! I had never seen this since owning the car (2 yrs to date).
Now this was a surprise as I hadn't noticed any misfires occurring, so I went into the Onboard Monitor Check & pulled up the Misfire Monitors (Mode 6) & sure enough there were recorded last count misfires on all cylinders except #5 but the EWMA counts were all at 0% which says that these misfire counts are very random & are definitely not sequential. Some background: I had also installed a set of cams (Lunati VooDoo #21270700 cams) roughly 2 months back & had the car retuned shortly afterwards. So I cleared the DTC (which clears all the data so all starts over) & started monitoring my car over several days w\ my scan tool checking the Misfire Monitors across cold starts & just before shutdown after parking as well as checking FT's & picked up some interesting info. First thing on initial starts I noted that the car would momentarily stumble sometimes as if a cylinder didn't have good combustion while spinning up...especially on a cool early morning 1st start but would straighten out quickly & go on as normal, whereas on startups later on in the day I detected no issues & the misfire total counts hadn't changed once engine had reached hot idle. LTFT's at idle showed B1 @ -7.8%, B2 @ -1.3%...large spread between banks is odd. The spark monitors showed that the misfire counts weren't consistent across all cylinders & were varying across all cylinders but no counts ever exceeded past 31 on any cylinder but the cylinders that consistently showed the most misfire counts regardless were #3, #7, #8. Now the plugs in my engine were changed out in 11-17 shortly after I bought the car (car had 139,487 mi at purchase @ 10-17) w\ MC HJFS24FP OEM plugs & the coil boots were also changed out (had this done at Ford dealership while having other work done due to owner's manual calling for changeout after 100,000 mi & had no maintenance records on car) so these plugs have a little over 10,000 mi on them....which is nothing. I remembered that during the Lunati cam install I didn't number match the coils to the cylinders that they came off of when removing them. In general this shouldn't matter but in reality this CAN matter as coil's secondary windings can get electrically conditioned to the plug\cylinder that it was installed on & can be thrown off if swapped to another plug\cylinder that has higher cylinder compression\resistance thru plug (fire weak or not at all) as well as primary windings due to connector contact\current flow resistance thru wiring so generated magnetic field during dwell time can be weaker.....the older these coils get the more they are prone to this. Ran olm checks across primary coil windings to see but not expecting to find much difference since having no dead misses....all checked out at .8 to .9 ohms so I knew that the issues had to be secondary winding related & since these coils were the OEM coils w\ a lot of miles on them I bought a new set of OEM coils (FP coil package) to replace them.
After installing these the amount of recorded misfires went down drastically but didn't completely clear out but the idle LTFT's didn't change either (engine power output clearly did improve due to better combustion from the hotter spark from fresh coils) so after giving it a few days to see if the spark misfire counter results would improve (then I clearly heard a coil misfire inside a plug well on B1 changing the engine speed during a warmup after a startup) I went & bought a new set of Champion Iridium #9406 plugs (went w\ Champions this time due to having good success w\ them back in my younger days) to replace the OEM plugs to see if I got any improvement (wasn't expecting to find any obvious issues w\ the MC OEM plugs). Gapped them to .040" per OEM spec & installed them making sure to keep the same coil on the same cylinder this time. As expected I saw no visual clues w\ the OEM plugs to point towards misfires....all gaps were at .040"-.042" so within spec, saw no broken\cracked\tracked porcelains or boots & all tips looked good, no burned electrodes w\ a light brown hue on the insulators (indicating slightly rich fuel mixture). But on initial startup after plug changeout the spark monitors went almost to 0 counts (had only 1 count on #1, #3, #7 w\ 2 counts on #8, rest were 0) & the LTFT on B2 went from -1.3% to -6.3% w\ B1 going from -7.8% to -7.0%. The change in LTFT on B2 definitely proves the cylinder misfires on B2 #7 & #8 were plug related (not necessarily no spark but a weak spark causing insufficient fuel burn thus throwing the cylinder accel velocities off & B2 O2 sensor picking up the extra unburned oxygen once in CL driving the LTFT to go much leaner on B2 vs B1..). Engine showed even more power improvement after plug changeout. Ran a vacuum test on engine at idle.....gauge needle was dead still pulling 21"Hg of vacuum indicating no mechanical issues & no vacuum leaks.
This got me to thinking about what could cause these misfires after a cam swap & the obvious thing that came to mind is the ground in advanced cam timing difference of aftermarket cams vs OEM cams when the cam phasers are locked at base timing (phaser full advance on 3V's) during startup. I know that these Lunati's have 14* advance cam timing ground in vs the OEM's 5.25* advance so the initial cylinder pressure would be higher at startup w\ these cams vs the OEM cams which can put a higher load on the ignition system to fire the cylinders when cold which could cause misfires (or uneven cylinder accel velocities) from weaker spark\no spark then ease up once the cylinders warm up, EOP builds up to allow the cam phasers to unlock so the PCM can now control the cams & retard the cam timing for EGR purposes which will reduce the cylinder pressure which could stop the misfires (or smooth out the cylinder accel velocities) at idle, but also the amount of fuel injected may be too heavy (rich) at cold startup (judging by the idle LTFT's once the PCM goes into CL along w\ the physical OEM plug inspection) causing plug fouling thus misfires but stops being an issue once the engine warmed up. This along w\ me swapping the coils across cylinders during the Lunati cam install most likely exposed the weaker ignition parts breaking down that were conditioned to the cylinders while the OEM cams (tune w\ OEM cams as well) were being used so coils & plugs were involved w\ my P0300 issue but fueling may be the main culprit that started it all.
Am curious as to what your tuner found\did w\ your tune as I know the HR cams have 19* of advance cam timing ground into them. I am planning a second session w\ my tuner for other reasons (had a false knock issue detected during dyno runs & afterwards had found an exhaust clamp hitting the gas tank shield on B1 side so wanting to verify the false knock was resolved after repairs) but will now add this to his list as well to revisit the fueling especially at startup\idle. I am also contemplating to change out the crank position sensor as well w\ a new 1 just to freshen all this up even though I can't detect any issues w\ it at this time w\ the equipment I have to use (am contemplating getting a better scan tool that can perform bi-directional testing & these sensors are pretty cheap in general) so will get w\ my tuner to see if he can see anything here (most likely not) as well while on the rollers this time.
If all does check out I may move to a hotter plug to compensate for the richer fueling......
