Hello Guys, I'm new and I'm breaking the unspoken rule of asking for help before giving any but I'm hoping that with your help I will be providing help to someone in the future with getting this solved. Ok, So for 2 Months now i have been trolling every forum and bought a Haynes Manual but cant figure it out. I have a 2008 Mustang GT and I did the transmission swap from Auto to Manual (Yes i know you all hate it and i should never do it but its done so stick to the problem at hand) EVERYTHING went great but one thing. (Note: i reused the Auto PCM and Auto Wire Harness and got a new tune with my bama tuner) My Speedometer does not work and I'm in Limp Mode with Code P061C. Now your first guess of bad speed sensor, already tested and replaced, both passed. Did a continuity test from the sensor to PCM and it was good, went as far to jack up the car, put it in gear and check for A/C Volts at the PCM. I looked up wiring diagrams for it but the best i could find was what ever one uses and it says 05 to 07 and i checked all the pin outs and they are correct (but could they have changed it mid 08?). I thought maybe the ABS speed sensor my play a part in giving information for speed like so cars but research says no and i have no ABS lights or TCS Lights on. I Checked for Ground, PCM works fine becasue they is nothing else wrong wit the car it runs fine just wont rev over 4k RPMs. I'm at a Complete lose and I'm hoping I over looked something because its a 08 and i followed the forum by Anothy05GT for his 05. So your mission if you choose to accept it is to help figure this out so the next time it happens they can troll my post and get the info they need!
