xxsurvivalism
I'll try to explain this the best I can. 2008 GT Deluxe 5 spd. Occassionally, I have a strange hesitation between idle and 3000. It only happens after the car has been driven and is shut off and restarted in a short period of time (getting fuel, or grabbing groceries for example). I'll restart the car, hit the road, and it hesitates til it gets to 3,000 rpm. After that, it runs like a champ from idle to wherever. "Alright, lets crack 3,000 in first gear to get rid of the hesitation." Super strange to me. Other than that, I've never had a better running vehicle in my life, runs like an old Singer sewing machine. And again, it only does it every once in a while. I have hopped in after a short stop and it ran completely normal.
Here are the mods that would matter in this situation:
- S&B CAI
- FRPP 62mm TB
- FRPP Intake Manifold
- Comp Cams XFI Camshafts
- BBK Long Tube Headers
- Offroad X pipe to Magnaflow mufflers
- Fresh Motorcraft plugs
- MSD Blaster Coils
- Fresh header gaskets
- Fresh intake manifold gaskets
Now about the TUNE. I bought this car pretty blindly. Previous owner had no idea what they had gotten into, I had to save the damn thing before something bad happened lol. I have no idea what tune it has on it. But I DO know that it would need a tune to run as amazing as it does with these mods. It loves a belly full of 92 octane, tried a few gallons of 87 on an empty stomach and it ran noticably different. Another clue to a tune might be a VGA cable and a USB female cable inside the center console? They've been routed under the console to somewhere under the dash. No idea where they go, maybe the VGA is hooked up to the OBDII port?
Hesitation aside, it runs pretty mild between idle and 3,000 rpm. A possible loss in bottom-end due to that Ford Racing Intake Manifold. Honestly makes it pretty streetable, good cruising speeds I suppose. Once you crack three grand, it's on like Donkey Kong. That engine really comes alive, like some kind of wack-ass 2 stroke power band. It's fairly impressive for a naturally aspirated 3V (4:10 gears, all the suspension mods and a FRPP 1 piece aluminium driveshaft help with that lol).
Any help or advice would be appreciated!
- S&B CAI
- FRPP 62mm TB
- MSD Blaster Coils
