No. It is not a habitual concern and the battery does not need to be replaced. I just stated what the battery goes for.Maybe includes labor? Or Ford's been taking a loss on every one sold
Same thing with a Hybrid car. Batteries are 10K plus.At that price, when it IS time to buy a battery, buying a new vehicle makes more economic sense.
I fail to see the logic of owning a hybrid or ev vehicle. May spend less on gasoline, but ultimately costs more to operate, if you keep it long enough to need a battery replacement.
Well, from that point, I did not put the planet into the situation of climate change, why should I foot the bill?I fail to see the logic of owning a hybrid or ev vehicle. May spend less on gasoline, but ultimately costs more to operate, if you keep it long enough to need a battery replacement.
Ps:the planet has been through several climate changes well before cars and industry was generating greenhouse gases. Its all in the ice cores.
If given an opportunity to drive one, do it! They are giant RC cars. Instant pedal response with acceleration and deceleration.I known eactly why it won't start. You lost your whine up key !![]()
Reman. Exactly.What? Hell no. A reman Prius battery can be had for ~$1K.
There is some form of counter. Its just like a regular battery when Cold Cranking Amps get to low there is as a higher chance the vehicle does not startFrom what I have read, there is an "end of life" countown on the batteries, in hybrids anyway. And many had good results in resetting the timer when the car's hybrid system shuts down with 'replace battery' message. What a great marketing gimick.
Yes and the planet has gone thru several mass extinctions too when volcanoes emitted millions of tons of CO2 into the air. CO2 that we are digging up and releasing again now at alarming rates. Don't get me wrong I love my Mustang but I know it is among the last of the breed. IC engines waste 70% of their energy as heat. We cannot afford to waste that much energy if we are going to produce it ourselves.
Dont worry. Im sure the electricity will not be generated with fossil fuels much longer. Nuclear power to the rescue! With the help of bird killing wind turbines, and acres of solar panels to help out. Then we will be left with just one toxic issue, where to put the spent radioactive materials.And yet we charge most all EV batteries with coal and fossil fueled generators, rape the local environments mining lithium and other elements, abuse the local population with subhuman working conditions and child labor, pollute their water with chemical runoff, but we are damn sure saving the planet.
Nothing more than a feel good, virtue signaling circle jerk!
Here in Canada, with a Prius hybrid vehicle, you give em your old batteries for the 'core', + a cheque for $3200.00 and they give you brand new batteries...with a 10 yr warranty.Reman. Exactly.
Same PLAN-ET.CHY-NA
