FS: Swines Mega Partout!
Swine
Located ATL, GA
**Last couple items, make offer!**
CHASSIS & BRAKING
AST 4150 Coilovers w/ Vorshlag Camber Plates -$2250 Shipped
OP Mustang 2005-2018 ½’ ARP Extended Front Stud Wheel Hub Kit -$330 Shipped
Swine
EXHAUST & INTAKE
AIRAID CF Intake w/ Water Shield - $450 Shipped
Excellent condition, all hardware included, ~6k miles on it. Includes the insert to use without a tune if you choose and also comes with Airaid rain shield for 2013-2014 S197’s that have hood vents that dump water on the intake filter when raining.
BOSS 302 Intake Cam - $275 Shipped
Excellent condition, 45k miles on it. Came out of my 2013 Boss 302. Changed out the intake cam’s on my Boss to L&M Intake Cam when doing my OPG’s. More aggressive cam profile then standard 11-14 GT/Truck cam’s.
CHASSIS & BRAKING
AST 4150 Coilovers w/ Vorshlag Camber Plates -$2450 Shipped
Rebuilt by Maxcy Speed with ~6k street driven miles on Michelin PSS tires and 0 competition runs. Come with custom shortened Whiteline sway bar end links as sold with the Vorshlag spec AST4150 coil over kits. Camber plate bearings also checked out as tight and good to go. These are some of the best dual-purpose coil overs on the market for street & competition use utilizing AST’s amazing DDP valving. Very street friendly 450/lb front and 200/lb rear springs make these your best bet for enjoying the ride and the turns.
Check out Vorshlags comments and the review in the link attached.
https://www.vorshlag.com/forums/for...cements/6851-ast-4150-series-damper-announced
“When the rebound adjustment is set to soft, the damper curve looks similar to an OEM street shock profile. When the rebound adjustment is set to firmer settings, the damper curve looks like a race shock. The most critical portion of the dyno plot area is affected the most - the portion at low shaft speeds. So much in racing happens at 0-3 inches per second shaft velocities, and that's where these pistons really step up the damping forces, when adjusted firmer.”
b322e623_b4f6_4eb4_96da_6a67ecd0e1ef_img_0850-jpg.57854
ccd029f6_19da_40b3_a640_20277258f9e0_img_3809-jpg.57855
73a0586d_f555_45ff_af8d_89004add5271_img_3810-jpg.57856
fa3ad619_3110_4be5_bb5f_de04765ac996_img_3812-jpg.57857
OP Mustang 2005-2018 ½’ ARP Extended Front Stud Wheel Hub Kit -$375 Shipped
Excellent condition, less then 2k street driven miles, 0-competition use. Bought new from OP Mustang preassembled with ARP extended and rounded studs.
5d13050e_b61e_441c_bd25_9abaf06be47e_img_3817-jpg.57858
18f8c738_e7a0_4d99_8d39_40a484eb068b_img_3816-jpg.57859
OP Mustang 15mm Spacers - $100 Shipped
Excellent condition, less then 2k miles. These are OP Mustang newest design. From OP’s website below.
“We have redesigned our spacer and removed excess material while maintaining strength. Our new 15mm spacers are only 11.8 oz for a total weight of only 23.5oz per pair!”
4f18177d_db10_4539_91e2_9dc682322522_img_3819-jpg.57860
2d1ef1e4_c6ce_430b_a36e_63a151616616_img_3818-jpg.57861
1dccb30a_af4f_43c3_8418_2cc310c5b584_img_3820-jpg.57862
GT500 Strut Mounts - $75 shipped
Part # BR3V-18183-D used with ~10k miles.
a3de8918_2a08_4ee9_9d0a_813470335581_img_3807-jpg.57863
c0c56ada_9f4f_45e0_ad4a_fe6bbced883d_img_3808-jpg.57864
DBA 5000 Rotors: S197 Brembo Cars - $475 Shipped
~15k miles of typical mixed driving on street pads with ~5k of those miles being on G-Loc R8 pads. R8 pads are very mild and very rotor friendly(see listing for R8 pads). These rotors have great life left, just need to be wiped down from some antiseize grease. I think they shaved ~5lbs/corner of unsprung rotational mass. Awesome upgrade.
c902ad6c_569b_49b6_b9a7_5c667f41534f_img_0373-jpg.58030
3b873436_7f30_4d5b_9cac_0d84691be5b0_img_3826-jpg.57866
ee47b38c_8830_457a_83cf_35f84618e0ac_img_3828-jpg.57867
[/URL
G-LOC R8 Pads: S197 Brembo Cars - $90 Shipped
A small chip on one pad from being dropped, but otherwise they’ve lived an easy life on the street with me. 50-60% life. These pads are AWESOME. Wide performance ranges, not to noisy, AMAZING initial bite. I used them on the street against the manufacturers recommendation.
“A high torque brake compound with a wide operating temperature range of 200°F-1250°F+ (93°C to 676°C+). Good initial bite along with excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Perfect for track day use with any tire and can still be driven safely to and from the track.”
FORD RACING Adjustable Sway Bar Endlinks - SOLD!!!
Mildly used, good bearings. Bought them used years ago and never got a chance to use them.
MAXIMUM MOTORSPORTS Adjustable Tie Rods - $100 Shipped
Good condition and tight bearings, comes with instructions.
OEM BOSS 302 FLYWHEEL - $make offer
Only fits Boss’s I believe. ~40k miles, perfectly fine flywheel.
Swine
OEM BOSS 302 Front Sway bar - $make offer
~40k miles, great condition, upgrade for a GT or V6
Interior
MAXIMUM MOTORSPORTS Adjustable Clutch Stop: SOLD!!!
SULLIVAN RACING Pedals – CNC’d Satin Finish - SOLD!!
New in box, medium width gas pedal (1” wider then oem gas pedal) to assist with heal/toe shifting. Full pedal set as shown
OEM MT82 Shifter and Leather knob – $make offer
Knob and shifter in good condition
MGW White Shift Knob - $make offer
Good condition.
Misc
BOSS 302 Car Cover - SLOLD!!!
Faded from use but no holes, perfect cover to use daily and save your mint cover in long-term storage.
HYPERCO 188A0250 Spring Pair: 2.25”x8” 250lbs - $make offer
Good condition, was used as an optional rear spring on the AST’s but I chose to run softer rates.
EIBACH 87217 Spring Pair: 2.25”x8” 200lbs - $make offer
Good condition.
FORD RACING 3.55 R&P -$110 Shipped
Bought used with the intention of installing in my Boss and never got around to it.
MAXIMUM MOTORSPORTS S197 Engine Support Beam - $50 picked up
Used one while installing my headers and pulling my trans.
https://www.cjponyparts.com/maximum...oHMrX6oMPKZlTOZb_s2Zz4jAdqJAuOBYaAnP5EALw_wcB
Excellent condition, square setup. I purchased this setup used as is. I never got around to mounting and running this setup. Setup has roughly ~5k miles of mixed street/auto-x use on an S550. ~80%+ tread life on center of tread, but the shoulders on the front two are more worn due to the physics associated getting an s550 to turn. These will make for an affordable and quick set of wheels and tires to go thrashing on track days, auto-x’s, and/or mountain runs and will be an excellent platform for going to wider 295 or 305 tires when the Bridgestone’s eventually wear out.
fe9c0c23_cea5_4f4e_a98a_1067407ec42e_img_3891-jpg.57986
d3b97dd7_3a29_4d98_b48f_9b1a968301ae_img_3892-jpg.57987
45203066_2146_4f31_a73f_f1147ab448bb_img_3899-jpg.57995
a3ec673a_a305_4248_a0e5_252a6058ea03_img_3896-jpg.57988
70598334_66aa_4f77_b4ce_ed9bcdf5bda9_img_3893-jpg.57989
f85dffb1_a1f6_4c3a_a92a_4a6ecbe11536_img_3894-jpg.57990
9af899f2_eacf_45b5_b20e_146a5e126dae_img_3895-jpg.57991
d44b8372_2026_45f1_9d63_e94b3146b54a_img_3901-jpg.57992
33ee76a8_32fd_44ac_87f8_fafa86c22357_img_3900-jpg.57993
Forgestar Center Caps (4) - $make offer
New in box
99278f76_0b25_4223_b550_d587d5a39f70_img_3834-jpg.57994
Richie
Indianapolis
I’ll take the wheel hubs and 15mm spacers. Can you text me please 3174696588. In a pinch need these ASAP if possible?
dark steed
Resident noob
Winder, GA
Interested in the front sway bar, front rotors & pads.
Shipping to 33478?
Swine hasn’t logged on since 12/18/20, but maybe he will see it. I’ve gotten some good deals on old inactive for sale threads before…
