cant figure out where this wire connector goes
whitmanink
denver pa
i put everything back together ,, and this one connector i cant figure out where it goes? any input on what and where it goes? i did take out my a\c ,, so maybe it went there ,, but an online search yeilded not much other than a wire schematic which i suck at reading
msvela448
Looks like the plug that goes on the skinnier of the two A/C lines which are / were under the air filter... It plugs into the a/c pressure sensor
Sent from my SM-N986U using Tapatalk
Monkeyporn
Wait is this plug on the drivers side down low ? Because the A/c compressor is on the passenger side. Also I have a connect I think looks like this that I have no idea where it goes either ? However my A/C is still installed and functioning fine.
whitmanink
denver pa
thanks guys,, im assuming its part of the a\c line,, because like i said, there is nowhere to plug this in at,, i mean the wire only goes so far,, but i wanted to make sure i didnt overlook or underthink sumthing,
whitmanink
denver pa
i plugged the compressor in on passenger side,, even tho it isnt the a\c is gone, they said about under the air intake,, on an a\c line , which is what i thought it went to ,, but again , it was about a month now since i started taking it apart ,, i took a video but never looked down at that area,, but from the video, it dose look to be like they said and go to one of the a\c lines under the air intake
Monkeyporn
Hmm do you have a picture of this A/C line under the air intake ? I'd like to see if that might be where my plugs goes as well.
whitmanink
denver pa
nope as you can tell from my pics, the a\c is all gone ,except the compressor until i get the compressor delete part,,hence why i asked where it went,,,
msvela448
It's kind of under the power steering hoses near the bottom of the airbox level... Solenoid looking thing screwed into the smaller of the two a/c lines in that area.
Best picture I could find quickly and I had to snip from a video on the internet.
