Here ya go Laga:Is there a right and left side knock sensor? Would it make a difference if they are switched?
Yes, if these knock sensors are switched across cyl banks from their original mounting, this can throw off the per cylinder knock threshold sensitivity tuning settings that were set in the tune based on the original cyl-to-sensor assignments as set in the tune (please note that these assignments also follow the cyl pairing to crank journal....ie, cyl #1 & #5 on the 1st pair, cyl #2 & #6 on the 2nd pair, etc in addition to firing order) making some cylinders more sensitive to knock than prior, some less.If they were swapped from their original location, would this show up as excessive detonation?
Sorry, just got back from road tripping my car..............Thank you for the information.
May I ask one more question since I haven’t heard from Lito in two days?
Will he be able to adjust for the new sensor location, if this is the cause of the detonation, or will the KS’s need to be put back in their original spots?
From looking at several stock tune's per cyl KS threshold mapping data, if all this was left stock then it looks like the Ford engineers initially tuned all this w\ the advent of these getting swapped across banks in mind thus it wouldn't make much of a difference (most likely why all stock tunes are set to apply per cyl KS spark advance\retard activity globally.....these 05-10 SO PCM's can be set up to apply per cyl KS spark advance\retard activity on a per cyl basis instead of just globally like a 2V, which explains the per cyl KS setups in the tune files & the advent of the 2nd KS to isolate 1 bank from the other 1 as noted). I found my tune file still set up to do this globally.......have changed it to apply this per cyl now......just like a Coyote.I talked to the shop earlier and he did not mark the KSs as he was not aware that it made a difference.
Now that info helps.Ok, I waited 3days and this was the response I got,
“It doesn't make much sense because they are pegged, if they've reached an stabilizing value, then yes, but pegged usually means that the noise is unrelated and no matter how it removes timing, is still there.”
I asked if they should be replaced. I hope it does take another 3 days for a reply.
Anybody have any ideas other than replacement?
The car runs great. No symptoms of detonation and no CEL.
I’ve done that. Lito said the KSs are maxed out, which means the noise is not from detonation. He can’t do anything. I’ve checked the exhaust for loose parts. Tomorrow I will check the front of the engine. Then maybe check the KSs themselves, but that means removing the SC.If you already have an SCT tuner you can datalog the knock sensors. I have charted them with an X4 and the live link software.
Do the KS signal plateaus show as flat spots in signal graphs? Like they go so high then stop & go flat for a time then drop back down? Is this happening w\ only 1 KS mic or both? Is this happening on only 1 cyl or is across all of them?I just looked at the LiveLink datalog, the KC values do go up and down. So when Lito says they are pegged, I believe it is momentary. There are plateaus, not peaks. That’s why he ask me to check exhaust for rattling.
Yes. That's what the per cyl threshold maps are for.......setting the KS sensitivity thresholds per cyl-to-KS assignment. Anything that attaches to the engine that generates any noise\frequency needs to be accounted for in the KS threshold maps or it'll be picked up as a false knock signal.Once it's all fixed...and...'back to normal', can the knock sensor sensitivity / threshold be adjusted in the tune? The story I got was when the PD blower is installed, the knock sensor threshold has to be reduced a bit, so it's not false tripping from the blower assy.
