4 im here again
Hello there,
I am trying to remove the timing chain components and the rear jackshaft bolt is in pretty tight. I tightened the front jackshaft pretty tight. wasnt sure of torque just hand tight about 50-60 ftlb. and i used an impact to remove the rear and what it does is that rear bolt spins the jackshaft causing the front to loosen. the jackshaft itself spins with rear bolt.
The other method I tried was using vice grip to chain holding it while removing the rear bolt. It didnt work. I slightly damaged the valve head area.
What should I do to remove the rear jackshaft bolt safely? Pictures below.
