Mustang GT 2011 to 2021 ZEX Blackout Wet Nitrous Setup
oldVOR
Northern Virginia
Mustang GT 5.0 2011 to 2021 ZEX Blackout Wet Injected Nitrous Setup. Everything you need for a turn-key installation.
All the components are new and have never been installed.
The setup includes the following:
ZEX Blackout Wet Injected Nitrous System w/Full Bottle
ZEX Plug-In Nitrous Bottle Heater
ZEX Nitrous Dual Outlet Purge Kit
ZEX Nitrous Safety Blow Down Kit
ZEX Nitrous Bottle Pressure Gauge
MSD Digital Window Switch
Nitrous Outlet Center Console Switch Panel
Extra NOS Full Bottle
Wiring, Heavy Duty Relays, Copper Tubing and Brackets Included
Local pickup, not sure if full bottles can be shipped.
$750
oldVOR
Northern Virginia
Looking at the ZEX Black Out photos, it looks like the only differences in the 05-10 and 11-23 systems are:
- Adapters for the fuel system tie-in
- Possibly: jet sizes for both fuel and nitrous
The rest of the parts appear to be the same.
I'll check with Zex to see if there's a parts list for the two kits.
oldVOR
Northern Virginia
These are the parts listed within each kit and I've highlighted the lines where the parts differ from one kit to the other.
oldVOR
Northern Virginia
man if this was for a 3V, id be all over it!!
This will work on a 3v, I highlighted the differences between the two kits. The fuel adapter, M5 x 40MM bolts, -4 AN (90* vs straight) fitting, along with some of the jet sizes are the only differences between them.
