Convertible top trim pieces removal
ryunker
Madison, SD
Want to remove these pieces for clean-up and refinishing. Has anyone removed these successfully? I have read the one on the rear is on with adhesive. Mainly the side ones are the priority, but the entire set is the goal. All guidance20260116_083615.jpg20260116_083625.jpg20260116_083633.jpg is gladly accepted. 2013 car.
Macman45
Resident Geriatric
Atlanta / Bay Area
I had a real hard time removing em. They use one way hooks that would rather bend the sheet metal before releasing. Be really careful.
MADGT
USA
Please let us know any lessons learned when you do this...mine could use some TLC...
ryunker
Madison, SD
Learned a ton, First off the side trims come off by squeezing the clips together from below. Lower the top a tad, there are five clips that get squeezed together to release shown here
then the part by the rear side windows have three clips, pry trim straight up starting in the front, wiggle and pry. these three are a spring type clip. see below
Same on both sides of the car. rear piece is easy peasy just slide it forward after side trims are removed.
I freshened up the trim with Dupont trim paint, huge fan of the stuff. It bonds great looks great and lasts like forever. Been using it for the best part of the last decade on all my rides.
Also learned no rust issues at all up inder the trims. Did not know what to expect, but a bonus in my mind.
