Help! Key is stuck!
OutlawEvans
Hello! I'm building a 2005 mustang gt for drifting and you can see my build thread in the drifters section if you want. Anyways after putting my car all back together from stripping out the interior I'm having an issue where the key won't turn down to the unlock position. Only time it does is if I disconnect the battery. Also it's manual transmission so there's no "make sure it's in park" or anything like that. What would make an ignition clylinder not turn all the way? I'm clueless
-also the wheel isn't locked to one side either. The front of the car is still on jackstands
What do you mean turn down into the "unlock" position?
There is the off, accessory, on, and start positions for the key. All of them you turn the key forward from the off or locked position. There is no accessory position when you turn the key back from the off position like in old cars.
OutlawEvans
It wont go all the way back towards me to the off position where the key releases
06 T-RED S/C GT
Carnegie, PA
Are you certain that your wheel isn't locked up ? That's the only reason I can think of that would prevent your key from turning..
I would think it is something mechanical. Bad ignition cylinder or like T-Red said, might be the steering wheel lock out of place and preventing the key from turning.
redfirepearlgt
For fun locate Fuse F68 in the BEC and see if it is there. If it is pull it and see if the problem goes away. If it does we can continue on to find the source of the problem if you wish.
Any chance the car was an auto and has undergone a manual tranny swap in? Just helps to know the answer rather than assume.
Sylver
Tyler, TX
This is happening to me too! How did you end up fixing yours? Shop I took it too wants 1200 to replace entire shifter assembly and ChatGPT is telling me it’s either the ignition actuator assembly or shift interlock solenoid. Thanks!
Well if it's the shift solenoid, which isn't all too uncommon, you have to replace the whole shifter. Probably $700-$800 new from a dealer. Maybe $120 used on fleabay. Took me a couple of hours to swap mine, don't know what the book labor is.
Kev555
Ireland
I did a swap on my 06' GT converttaible with a Dorman unit. The OEM shifter was missing the gate cover and the t-handle looked like it had been gnawed by a small dog? LOL
Rockauto has them for $160.00
Bought one of these Dorman versions from Rock auto too as mine felt worn and the plastic blind cover was broke as well. Good improvement on the old unit.
Autokyrios
VA, USA
If the range sensor isn't hooked up or is damaged, it won't release the key. It has to know it's in park or neutral. Disconnecting the battery kills the logic. That would be my first thought. You can try moving the shifter out and into D or N a couple times and see if it lets go (not a solution, just a test).
