My bmr sway bar should clear, when you have a moment to check what was the size?I went with race stars 15x10. I believe the offset is 45 or 46 mm. I believe I use a 28" x 11.5" Hoosier QTP. I can look when I get home. You can probably go with a 29" tall tire but but the narrowest tire was 12.5" wide and thought it might be too wide. I believe you will need a relocation bracket for the sway bar.
What was your setup?When I changed up my setup, I had (aftermarket) swaybar interference. Instead of relocating it, I just cut the ends off, just past the grommet.
My street setup. 20x11 with 305/35/20's i think the tires are close to 29" tall.What was your setup?
