whitmanink
Yea I share many of the same thoughts as you have on this subject matter,Not doubting there knowledge and experience. Just don't see the point of not putting in all new while the heads are off. Do the job once! As a customer if you are doing your own work and pull the heads you have alot of your own time tied up. If in fact they tell you all the guides don't need to be replaced and then a short time down the road a guide has an issue, you are going to be pissed. I kno0w I would be.
But each person does have certain goals and or money restrictions, or in my case life gets in the way and finds must be moved around and sometimes I need to cut corners to get it done and going .
Not saying that was the case ..
but I just try to look at all angles because a lot of times a lot more is going on than what meets the eye..
But none the less
