A/C refill DIY - questions
GriffX
Rural Germany
Hello,
last year I refilled the A/C system with a DIY refill bottle. Due to clImaTe cHange or whatever, my EUdSSR forbid to buy R134a for private use and made special taxes for R134a import, so a refill at the shop is expensive now.
At an ambient temperature of 86F I only got 50F at the vent, so I bought a DIY kit with isobutane/propane mix (R600a/R290), equivalent to 620g R134a.
The initial pressure was 20 psi and the goal pressure was 45 psi, the bottle I had was enough to achieve 40 psi, so not fully recharged.
The last week it was up to 100F outside and the A/C took approximately 1 minute to get to cold temperature. Before I buy a new bottle, my questions are:
1. Is it normal that the system is so low after 18 years? I guess yes, but my other even older car is not low on refrigerant.
2. When I remember, it took always a bit of time until the air at the vent was really cold from the beginning?
3. If I have a leak, it is very small, so probably an hardened O-ring. Does someone has experience with leak stop additives?
4. I think I buy another bottle without the leak stop. The leak-stop bottle contains also compressor oil and there is no oil leak to see, I'm afraid to overfill with oil.
The price of these R600a/R290 bottles are a ripoff, but a refill is done in a few minutes and I think fluorinated compounds shouldn't be escape in the environment at all. The persistence of the new R1234yf is 100 years (it degrades to trifluoracetic acid which rains down. TFA is not biodegradable and must be burned to get destroyed, so it will accumulate in your lawn, no way to avoid this, but DuPont and Honywell are happy). Sorry for my rant ;)
Thanks
brasil
Germany
@ GriffX. is it the kit from Poland ? Bought one...but it did not work . Was for the 2008 Fiesta from my wife... went to a BOSCH Station nearby ...the charged the system.. for 80-90 Euros. Problem solved
Kev555
Ireland
I got mine filled professionally about two years ago but it didn't cool very well, compressor kept kicking on and off every few seconds, I got an orifice tube and a new air dryer the next year and I tried topping it up with a home kit. It was at the right pressure but then but no cold air again. I did get metal shavings in the old orifice tube so I assumed the compressor was on its way out.
GriffX
Rural Germany
A/C Doctor, bottle with valve, was easier than I thought
GriffX
Rural Germany
That's bad. Was it a problem to get a new compressor?
Samos3
St. Louis
Hello,
Thanks
Not unusual after 18 years. Some would be surprised it took that long. I started having to do the small can refills a couple years ago.
A/C systems like to be used once in a while to keep everything oiled so seals don't dry out.
Kev555
Ireland
I never got one and I might never get one. Yes it could be an issue getting one ATM with the Russian steel rule. Rock auto have them, I only drive it in summer and our summers usually aren't that hot. Maybe if I really want to have the last broken bit working on the car I might tackle it at some stage.
Samos3
St. Louis
96*F right now and heat index is 105.
The more humid it is the better the a/c works as the extra moisture pulls more heat out of the condensor.
And rpm helps....
Leaky 134 systems are so common, every system I got has green dye in it, from the factory. 08 van, the stang, our daily.
If you think you have a very small leak, add dye when you service it.
If it already has dye, just find the leak.
Ps: daily is a grand marquis. Receiver/dryer rots on those cars. Dye was easy to see on the bottom of it.
GriffX
Rural Germany
That's a good point, my car goes in winter storage, my others doesn't. And the newer A/C systems are on all the time, they change the compression ratio between on and off, so oil circulates all the time.
GriffX
Rural Germany
I think it’s the opposite. Humid air transfers heat worse than dry and the AC works harder to dry the air vs cooling.
Evaporation enthalpy, for evaporation you need energy and for condensation the energy must be transferred backwards and in this case more R134a needs to get vaporized.
GriffX
Rural Germany
Does it from factory? I searched with an UV torch and could not see any suspicious connection. So maybe I'm good and the combination not fully recharged and R600a explain the changes I noticed.
Samos3
St. Louis
Out of my depth here. I understand on the evaporator side (inside the car/house) that more humidity complicates cooling. On the condensor side, does the denser humid air absorb more heat from the condensor than dry air? Rainy days seem to increase the heat transfer as well.
GriffX
Rural Germany
That is a more complicated system than you think.
Humid and warm air enters the heat exchanger. The temperature of the surface is below the dew point of the humid warm air, therefore the water condense at the surface, transfers the enthalpy to the liquid R134a which itself goes into vapor. This liquid R134a is gone and cannot cool the now dry air, so the A/C system is less effective. But, now you blow dried air out of the vents and this dry air can cool your skin more effective, because it can evaporate the sweat on your skin more effective and this evaporation enthalpy of the vaporized sweat on you skin, together with the cold air cools more effective than humid air. :)
Samos3
St. Louis
I am assuming you are talking about what is going on inside the car. At the other end of it....out in front of the radiator....how does the ambient hot, humid air flowing thru affect the shedding of the heat there?
Overthinking it. Its all about temp differential when it comes to heat transfer. And at some point when its super hot, system BTU capacity. Humidity has minimal effect.
Samos3
St. Louis
That's not unheard of....
But....two thoughts come to mind, one is the misting systems used on a/c units in places like Florida that use evaporative cooling on the fins of the condensor to carry heat away. Similar to rain going thru the grille and radiator.
The other is the heat/energy capacity of the cooling medium. Think trans coolers (fluid to fluid) built into radiators versus a fluid to air cooler (the add-on tube and fin coolers).
Not just temp differential, but the differential in capacity due to density of the cooling medium.
GriffX
Rural Germany
Overthinking thermodynamics? The question was if a A/C system is more or less effective in humid air.
And in Las Vegas or Phoenix or elsewhere the fine water spray cools the air because of going from liquid to vapor state.
That you can refill the system with no scale, just by measuring the low side pressure is because you use the relation between the temperature and the pressure of the R134a vapor. The temperature you need to measure is the air temperature going into the blower. Then you know also the temperature of the R134a at the exit of the evaporator, the volume is fixed and you get a relationship between the mass and the pressure. You look in a temperature/pressure table and fill up to the desired value.
pV = nRT with V,R,T ~ const.
Again, way overthinking it.
Evacuate system. Blower on high, idle it around 1200 rpms, and start adding adding refrigerant. Stop when you feel the evaporator discharge line (the larger one) get cold. Job done.
