Newby with blown engine/Whipple
eleanor06
Rebuilt motor parts
Listed below is this kit they are installing.
It is part number 14410, Forged
4340 crank, H-beam rods and Arias 2618 forged pistons. 8.8:1 comp. with 52cc
heads. Your engine was 9.8:1.
Competition assembly for Ford modular 4.6L intended for internal balance 285cu.in. engine size bore sizes available: +.020 Price: $2373.75
Pistons and ringsArias forged 4032 -17.0cc inverted dome
ring size:
1.5mm 1.5mm 4.0mm
Crankshaft3.5540" stroke standard 4340 steel
428135545933
Connecting rods5.933" standard H-Beam
CRS5933F3D
BearingsClevite CB1442P rod bearings
Clevite main bearings
EagleStroker
N/A Junkie
Memphis, TN
I have to ask why stock stroke? And I would of definitely gone higher on compression! Good luck with the build up :beer:
psfracer
billy badass
Valencia, CA
Yeah, now the high compression should not be a concern since you are putting a good h beam rod in it.
And as far as compression---its detonation that kills these things. If he is saying its rpm, then how did it let go at only 3500 rpm in which you stated that earlier in this thread? Its too much timing combined with cheap gas which will cause detonation that kills these motors.
In any case, with the lower compression you will be able to run more timing at the same boost level with pump gas, and in the end (since you are not going for 600+ rwhp) it probably won't make alot of difference. You may have to run a little more boost and timing to make up the difference.
lostsoul
2014 vett or 2015 stang..
Gay Area
Do the right thing and have them order a MMR short block and call it a day, can't go wrong with MMR.........
HOLY SHIT Batman!! I just did not see that coming. You should do a search on MMR here noob before you promote shit. Its not good to give crap advice to people. I threw up in my moth when I ready this... ahhhh... need to relax now... breath.... breath.... ahhhhhhhh
FUCK MMR!!!!! :piss:
one eyed willy
Pizzle fo shizzle
Lakeland FL
and this coming from a guy with a MMR block??I realize some people have had issues with MMR here,but there are other people that have not and had good success with thier stuff, i personally have had good service from them, nothing major like a block but i wouldnt get so worked up over what he said about MMR. I personally would not want to us them just from their rep on this board, but there are plenty of people with no problems, not that i am in anyway trying to stick up for them.
retfr8flyr
The Old One
Providence Forge, VA
I'll go along with that "Fuck MMR" they have cost me both time and money. Money is one thing but at my age time is not replaceable.
Earl
lostsoul
Gay Area
I had an MMR block.. would still have it if they didnt over bore a "new" block so much. Its ok.. just another 1200 pissed away. =-/
Go back to Mustang Forums and tell all your butt buddies how you..."told those S197Forum guys a thing or two.."..Then head on over to Vtec forums and tell all your fagget friends about the rev and burnout contest you won last night at the local 4H club you retarded sperm..
A little "testie" are we..................LMAO (I won)!!!
