05bluestang
Resident Riceburner Kille
I also posted this on MM. I'm batteling this intermittend check engine light issue. It started after the SC install, it would trow a CEL light at ~85mph, I get off the gas, coast and it goes away, no codes stored. Back then I had Tillman and Techco look into the issue, the tune was good according to them. They thought it was a TB issue because they had problems seting up the TB due to the return spring. Techco a while ago sent me used TB from their stock inventory. It ran good with no issues for a while and now the stupid check engine light is back, when we tried to pull a code there are none. Only difference now it does it at any speed at any given time. I took the car to Tillman, they had it for two weeks, the fracking thing would not throw a CEL. I take it back home (45min drive) no CEL, my kid takes it out and withing 10 miles it throws four CEL's, again no codes. I am somewhat stumped with the fracking thing.
Question, is it possible it could be a simple intermittend TPS issue?
