currious about high flow cats
Stormbringer
Will a pair of high flow cats (Bassani specifically) be sufficient enough to prevent the 02 sensors from tripping a CEL? Has anyone installed them in an 07+ without issue?
Stormbringer
Well I have an off road pipe now and it threw one despite the MIL eliminators I put on.
ZmanM3
The Evil One
Jackson, NJ
Hmm, MIL eliminators should have fixed it. Thats what I ended up doing instead of going to get it turned off in the tune and it worked like a charm.
Stormbringer
Well most places list the eliminators for 96-06... Thats why I was wondering if something had changed in 07.
Royb
irving TX
I have them & sometimes turn the cats on & off with no issues. Make sure you get the expensive cats with the metalic substrate. The other type of cats are cheap and break apart like a a clay pot. (and if I recall someone on the board (Don??) had one go to hell (not bassani but still clay substrate and it cost him a motor)
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Just to clarify, the Dynatech cat that failed and grenaded my motor had a stainless steel core, not clay.
don_w
San Diego, CA
wow, how did that happen?
That's an old story from early 2006. It's posted on other forums, but not here.
Oh, what the hell... might as well copy and paste it here for posterity. Almost everyone likes carnage pics. haha
Originally posted February 28, 2006
Before I offer our theory on what may have happened, I‘ll share some pics I took during the teardown. Note, there is a key piece of evidence missing from these photos. More on that later.
ENGINE REMOVAL
ROD THROUGH BLOCK, DRIVERS SIDE
HOLE IN BLOCK, PASSENGER SIDE
DEBRIS IN OIL PAN
WINDAGE TRAY DAMAGE
PASSENGER SIDE CYLINDERS, FRONT TWO DAMAGED
#1 PISTON, CRACK VISIBLE JUST UNDER THE “S2” MARKING
CRACKED CYLINDER WALL, NOTE WATER SEEPING IN
EXAMPLE OF DETONATION VS. NONE (MY PISTON IS ON THE RIGHT)
BOTTOM SIDE OF PISTONS
TOP SIDE OF PISTONS (SOME GOUGING, PLUS CRACK IN RIGHT ONE)
So… what happened? Well, let just say my cat blew its wad.
When I was removing the exhaust system prior to pulling the engine, I had trouble getting the X-pipe out of the cat. Once it came loose, a large chunk of the catalytic converter material fell out of the X-pipe on the driver’s side (see first three pics below). It had blown out of the cat, and lodged in the pipe. And, on the header side of the cat, the material had basically caved in on itself (see fourth pic). The combination of the collapsed inlet side, and the chunk blocking the outlet side, effectively eliminated the ability for the engine to breathe on the left side.
Although it seemed to drive fine that morning on my way to the shop, we suspect that this cat may have already started to self destruct prior to my arrival. When the new pulley went on, it is possible that the added boost sealed the fate of the cat; maybe even on the first dyno pull.
So, with the left side of the engine all choked up, the right side was left to absorb most (if not all) of the boost and energy of the engine. The amount of pressure in the right side cylinders must have been staggering, considering all the air the blower was forcing into the engine. When Adam was tuning the car, he would modify the timing tables to add timing, but as a safety factor, he allowed the car’s computer to retard timing if it determined a need to. Since half the cylinders were not functioning correctly, the computer kept retarding timing. It’s obvious now why the car was not making any power at all on the dyno, and never had anymore than 14 degrees of timing in it all day. IMO, no amount of skill by Adam as a tuner was going to stop the inevitable.
In the end, we believe that the clogged exhaust on the left side placed an inordinate amount of stress on the right side of the engine, ultimately ending in the untimely death of two rods that aren’t the strongest rods to begin with. There is just no way that four cylinders could handle it alone.
Bottom line for me… the premature death of my engine was not due to a tuning error, nor can it be blamed on the Kenne Bell supercharger. Given the circumstances, this would have happened no matter what power adder was on the car, and no matter who was tuning it. I still have 100% full confidence in both Adam as a tuner, and in Kenne Bell’s product.
p.s. I’m also wondering if this cat was starting to collapse on itself a couple weeks ago, creating a partial blockage, and possibly contributed to the P0340 code I was getting on the passenger side bank. Not sure on that one… your opinions are welcome.
p.p.s. And yes, I will be contacting Dynatech regarding this issue.
don_w
San Diego, CA
Here is some more from February 2006
Take a look a these photos!! This is the path that I believe the “projectile” made when it came apart. The force must have been tremendous. The piece of the cat actually made the bend in the X-pipe segment, and eventually stopped when it hit the A/F meter that was in the bung. You can see how hard the impact must have been… it crushed part of the “missile”. Amazing…
matt texass
dam all that does is make me worry about my cats.......... what causes cat failure
Royb
irving TX
in Don's case it looks like "Defective Manufacturing" A one piece metallic substrate should not break apart. As of a couple years ago to the best of my knowledge bassani only had one set of the bassani cats with metallic substrate come apart & that was due to a backfire explosion on a very high horsepower car (JPC racing).
for the most pars cats fail due to to much fuel, wrong kind of fuel, & age.
