whtcanbrwnd04u
KDWs FTW!
Shotokan those rims look great. Can you please tell me the backspace on those? That is the look that I am going for .
I've got a set of 18x10/9 wheels that I'm ready to buy some tires for and need your opinion on which to get.
Here's what I'm looking at:
NT555 in 285/40 and 275/40
or
Goodyear Eagle F1 Supercars in 285/40 and 255/45
How do they compare? I have the Nittos on now and like them but the F1 is cheaper everywhere I've looked. The only downside I see to the F1 is that I can't run a 275 up front. Your thoughts?
Rolling thunder, not stealing your thunder.. I am also looking for similar sizes, just showing Black baby the Falkens.
BFG also has the T/A KDW
285/40ZR18 and 275/40ZR18 or 255/45ZR18
295/40 & 255/40, notice the smaller sidewall, I need to replace wheels & tires... have not decided if I will stay 40 or go 45 this time. I like the rake, but sometimes the front well seems a bit empty... thinking with my new CS front bumper I can up the sidewall without loosing the nose down appearance.
What springs do you have?
FRPP's the ride height is a little weird due to the tire sizing
255/40/18 is 26.03ish diameter
295/40/18 is 27.29ish diameter
Gives more rake than just the springs.
Full suspension setup is Tokico D-specs, BMR sways front & rear, BMR adj UCA & fixed LCA's with reloc brackets, Steeda adj panhard & brace.
I am still trying to figure out next tire & wheel setup, might go a bit taller in the front, the 255/40's look a bit small in the wheelwell at times, hoping the CS fascia I put on will cut down a bit on the height increase in the front. I really like my 295/40's out back, but that is the only tire available in it, would really like a 305/40 ish, but NOT a drag radial
