i'm going to attempt getting these back on, the bottom of the lugs that touch the washer look boogered after 1 time on, TD torqued em to 100, whats recommended?
well, i successfully tapped all 4 shanks that were buggered and cleaned up the other ones as well,
the studs were a little tougher and you had to put the spinny tool on with a handle on one side, spin half turn, take handle out, put handle in other side, spin halfway, etc..... i got the threads that were buggered bad, and cleaned the rest up
tried the lugs without the wheel, spun on fine all 10
the race stars are a little goofy, i don't like em and i do.
welds and bogarts have a round hole, and you simply have to start the shank on all 5, then pull the wheel over it and tighten each one so much at a time
the racestars have a hub which centers it, but the holes are goofy, they are cut in an oval and the washers are oblong instead of round, i still don't get that, it's not like you can set them up and when the fatter part goes to the bottom, it gets stuck there
who knows, anyway, i guess i'm going to attempt the track and see what happens
