Well thanks to that asshole midget from houston I found a 96 cobra "roller " for a great price so decided to pick it up .........well by the time I left with it monday night it came with a 04 cobra motor and a mvb aode lol . Man was monday not my day I start out by leaving later than I wanted to thanks to my son's school then get to beaumont only to get stuck behind a wreck and end up stranded on the interstate for damn near 5 hours ( they were doing road construction and the lanes were barricaded off so no cutting through a median ) . Then get to the trailer place only to have them dick around for over a hour so instead of getting there for 12-1pm like I planned I got there at damn near 7:30 .
This is a pretty clean car but has some work left to be done , mostly just time consuming not bank account consuming . I think it is a pretty safe bet to say every harness/connector in the whole car is disconnected from the headlights to taillights and I have to put a wrench on every nut/bolt from front to back ( may be partially because of my ocd though haha ) . First things to be done is connect/splice/delete the harnesses , modify the cage to put swingouts and figure out a new window net mounting , run all the fuel lines , scoot the seats inward about 3/4" to give more clearance on the cage , then it's off to the drivetrain teardown and rebuild . My realistic goal for completion is 6 months or better mainly due to me doing most of the work myself and only being home 1/3rd of the year . Anyway this is the parts pile so far
Motor:
04 cobra motor & harness
22k miles on the motor
ported stage IV steggy eaton
Richard Racing 2.80 upper pulley
Meziere Electric Water pump
BBK long tube Headers
MotoBlue 60 Lb. injectors
Aeromotive Return Style Fuel Rails
Metco Pulleys
Metco 4lb. crank pulley
Accufab Single blade polished throttle body
Accufab carbon fiber wrapped plenum
JLT CAI/K&N filter
SCT 2400 meter
Fluidyne heat exchanger
Canton aluminum ice tank
Transmission:
AODE
Performance automatics reverse manual valve body
P/A trans brake
FRRP deep sump pan
Abesto clutches
OD billet drum
Precision industries N/L 3200 stall (multi disk)
FRPP aluminum DS
Fuel system:
Aeromotive A1000 fuel pump NEW
Aeromotive 100 micron filter NEW
Aeromotive fuel external pressure regulator NEW
Aeromotive Y block NEW
10 gallon aluminum fuel cell w/ foam insert NEW
Aeroquip stainless braided fuel line -10 (15ft) NEW
Aeroquip stainless braided fuel line -8 (20ft) NEW
Ron Davis custom 3 row aluminum radiator
sn95 electric fan
Rearend:
8.8 with tig welded axle tubes (done in jig)
Moser 33 spline axles NEW
Moser 33 spline spool NEW
Moser C-clip eliminators NEW
Ford Racing 4.56 gears NEW
Ford Racing Rear cover/girdle NEW
Steering/Suspension:
UPR Pro-Series front tubular suspension
UPR bump steer kit NEW
UPR/QA1 14" 175lb front coilovers NEW
UPR Pro-Series rear suspension w/upgraded hiems NEW
Steeda caster/camber plates NEW
Strange 10 way adj struts and shocks NEW
Welded torque boxes
Fox body rear springs
Flaming River manual rack (Sn95) NEW
Flaming River steering shaft (Sn95) NEW
Aerospace manual brake conversion (Sn95) NEW
TCI line lock/roll control NEW
Summit proportioning valve NEW
Chassis:
Wolfe 10 point Chromemoly cage (painted black gloss)
2"x2" through floor frame connectors with kickouts
Stroud window net NEW
Simpson 5 point harness BLACK (2) NEW
Corbeau Forza seats (black)
UPR air bag deletes (painted with saddle dye) NEW
Skinny Kid aluminum rear wing NEW
Weld ProStars 15x3
Moroso D2 26x4.5-15 NEW
Weld ProStars 15x10 (6.5 bs)
M/T 28x12.5 ET Streets
M/T tubes NEW
Taylor aluminum battery box NEW
Flaming River on/off switch NEW
Flaming River switch rod (for on/off through bumper) NEW
Russell stainless braided brake hoses NEW
All new hard brake lines
Repainted engine compartment and inner wheel wells
Motor:
Metco Pulleys
JLT CAI/K&N filter
SCT 2400 meter
Transmission:
AODE
P/A trans brake
FRRP deep sump pan
Abesto clutches
OD billet drum
FRPP aluminum DS
Fuel system:
sn95 electric fan
Rearend:
Welded torque boxes
Chassis:
Weld ProStars 15x3
M/T tubes NEW
